I’m trying to figure out what are all of the SR and SRC resistor clusters in the switch matrix on a F-14 Tomcat. Any help is appreciated. Thank you!
The SR is a resistor network. Some of the resistor networks are discrete and some are bussed. Consult the schematic for more information.
The SRC is a resistor network with a capacitor network. These are NLA (no longer available). The capacitor part is not present in the currently available parts. Fortunately the absence of the capacitor does not appear to cause problems but the circuit was designed with the capacitor. Williams used the SRC in the switch matrix circuitry for System 11 and System 11A. When the board was revised to System 11B the unused connector 1J9 and associated circuitry was removed and the board real estate was reclaimed to replace the SRC with discrete resistors and capacitors.
Quoted from DumbAss:The SR is a resistor network. Some of the resistor networks are discrete and some are bussed. Consult the schematic for more information.
Thanks for the response. I have an 11A system. I ordered an SR11, SR14, SR9, SR10, SR12, SR13, SR15, and an SRC6 from Marco yesterday. They were showing they had the exact replacement for part number 5019-09669-00 which is the part number for the SRC6 cluster, so I’m assuming it has the capacitors. I’m trying to find out if any other of these SR or SRC resistors on the board are tied into the switch matrix in any way such as SR3 and SR17.
Quoted from Lpilot1:... Marco yesterday. They were showing they had the exact replacement for part number 5019-09669-00 which is the part number for the SRC6 cluster, so I’m assuming it has the capacitors.
"RESISTOR SIP 10 PIN 1K 9R 10 5%
Single inline 10 pin bussed resistor network 1k 9r 10 5%
Reference: Bourns 4310R-101-102LF"
This part is not 100% compatible. It does NOT contain the capacitor network. It's a 10 pin 9 resistor bussed network resistor. This means that the 9th resistor will connect directly to ground if you install it on your board. You want a 9 pin 8 resistor bussed network resistor (Bourns 4609X-101-102LF available @ https://www.greatplainselectronics.com/proddetail.asp?prod=4609X-101-102). For the part you ordered from Marco you should cut off the 10th pin (9th resistor) as the 9th resistor connected to ground is an unwanted "side effect" when installing this part.
Quoted from DumbAss:"RESISTOR SIP 10 PIN 1K 9R 10 5%
Ok. I have a couple of these already: 4610X101102LF
I guess I’ll cancel the one from Marco and use one of these instead and clip off the 10th pin. Are there any other SR or SCR clusters associated with the switch matrix? Didn’t know if SR3 or SR17 were. Thanks again!
Quoted from Lpilot1:Are there any other SR or SCR clusters associated with the switch matrix? Didn’t know if SR3 or SR17 were. Thanks again!
Quoted from DumbAss:Consult the schematic for more information.
Quoted from DumbAss:[quoted image][quoted image]
I’ve always wanted to say this....... Thanks Dumbass! Lol!
Does the end pin need to be clipped off on the replacement SR resistors just like the SCR ones?
Quoted from Lpilot1:Does the end pin need to be clipped off on the replacement SR resistors just like the SCR ones?
No.
The "SR" is a bussed resistor work. It contains ONLY resistors. Use the exact number of pins.
The "SRC" is a bussed resistor/capacitor network. The marked pin on the SRC is the common pin for the bussed resistors. The last pin on the SRC is the common pin for the bussed capacitors. Either cut off the last resistor for an identical number of pins as the footprint or use a part with one less pin than the footprint.
Note the common pin before installing so you have the correct orientation / polarization.
Quoted from DumbAss:No.
Ok. Thanks! I understand the white dot on the board and the dot on the resistors which is pin 1 need to match up. I will clip pin 10 on the SCR one only.
I’m happy to report after replacing the SCR6 and SR10 resistors the issues have seemed to have gone away. I’ve played at least 10 games with no issues.
This page was printed from https://pinside.com/pinball/forum/topic/sr-and-src-switch-matrix-f-14-tomcat and we tried optimising it for printing. Some page elements may have been deliberately hidden.
