I came across a Spy Hunter pin last week. It is in great condition considering it has been rarely used over the past couple of years. After fixing a broken connection to the speaker, it was ready to release to the kids. What a hit! After a couple of days, the bumper stopped working. After going over the playfield, I noticed a few other switches that stopped working. Here are the switches that are not working.
Bumper
"H" target (In SHOT)
"E" target (In AgentGK)
Left Oil Slick rollover-button
All of these worked normally and appeared to all fail at the same time. The lights for the targets are still lit.
I am new to this... and here's what I have done so far. I first checked the four switches for obvious problems, broken wire, etc. All look good. I then ran the self tests. During the self test, the bumper works.
The first time I ran the switch test, there was a stuck switch found. If was the rebound switch. The rubber was up against it. I was happy to find this and quickly adjusted the switch and rubber to fix the problem. After restarting, the problems remain. I ran the self tests again and the system reports no problems.
What other steps should I take? Are these four switches related somehow?
Thank you for any advise!
