I'm working on a Spy that has been sitting for 3 years. Was working prior. MPU led locked on. Cheap Squeak led also locked but will cycle when pressing red reset button. No sounds. I started with the test points on solenoid driver. Disconnected MPU. TP5 12VDC is running at 16VDC, should be 11.9 +/- 1.4V. Moved to the sound board. TP1 was 14VDC, should be 11V. Moved to power supply. TP3 reading 18VDC. I swapped out the rectifier board and got the same result on TP3. It should be 11.9 +/- 1.4V.
So is 16V enough to lock up the MPU and is 14V enough to lock the sound board? Should I be looking at the transformer? Do not worry about it and try another MPU? I have a spare with a NVRAM that has also been sitting 3 years and I don't want to risk burning it out until I'm sure the extra voltage is okay.
I appreciate any input.
