This is my first post and i would greatly appreciate any help. There are no repair facilities in my area for pinball machines.I am not a pinball machine tech. What I am is a dad of twin girls who ask, daddy can you fix our pinball. I do have a general knowledge of electronics and can follow a schematic. I have checked what i can check with what information I could find online. I have a Spring Break Machine, Ive had it for a few years. It was turned off for a while, when turned back on it would not boot..I had no display when i turned it back on, all that lit up was the lights in the playing field. I removed and re-soldered the main chip on the mpu, no change. I checked the voltage at the 12 to 5 volt power supply. The voltage was low, I repaired the board and got the power back to a steady 5 volts. My display lights up now and goes through the paces of high scores and the name of the machine across the display and all 4 score displays light up. It has a button installed for free game play. When you push the button it gives you the games and shows them on the display and the dog barks showing the free game button has been pushed. When you push the button to play the game the display zeros out and is ready for score. This is where the game stops functioning properly. It will continue to try and bring the ball out in the launch area but the solenoid at the end of the shoot does not retract to allow the ball into the launch area. If you manually retract the solenoid and allow the ball to pass on through it is launched into the play field but the flippers don't work and it will not score if something is hit. Also when the ball rolls back into the shoot it is immediately launched back out to the solenoid without pushing the flipper to release the ball. If anyone could lead me to a possible problem I would greatly appreciate it.
