On my Spring Break, there are 8 white flash lamps , located beside the "vacation " lamps that are supposed to fire at ball drain and other times. Mine are not working. I know there is an auxilary lamp driver under neath the pf, have reflowed solder here. these are also driven by a coil solenoid/relay located at the bottom front of playfield. If I activate this manually , the lamps work. I am trying to find out what driver actually controls this relay/coil . I cannot seem to source a wiring schematic. Any thoughts on this problem. I am thinking the driver on the auxilary board ... Thanks..
