Ive been creeping the forms for awhile now, Doing as much research as possible before I asked this question,
My spring break wont launch the ball, from either location. It has on occasion worked for what ever reason, so I have tried to trace back loose connections ect but cant seem to find anything. Im new to pinball repair but have a lot of experience with arcades in general.
The game otherwise works perfect if you just put the ball on the play field manually, Ball will eject into launch shoot, but doesn't go further then that. Both coils are new, and I believe when I checked for voltage the coils did have voltage going to them. I cleaned up all the switch contacts, And checked the switch matrix, Ever switch operates how it should.
Any help or thoughts on where to go from here would be great.
