So...
You've got a whole lot of intermittent problems!
The first things I do when I have a lot of things that are giving me problems is to shut the game off, and then I:
Firmly press on the big square chip on the CPU board. If this is a little bit out of it's socket you'll have the problems you've been seeing.
Re-seat (unplug and plug back in) the following plugs on the big power board: On the right side, J101, and especially J102 (this is where power comes in for the logic, and bad power can cause all kinds of problems.) On the left side J114 (it's just below the big ribbon cable). This provides power to the CPU.
Reseat J210 on the CPU board (it's right next to the J114 on the power board that you just reseated). This is where the power comes in to the CPU.
Reseat every ribbon cable.
D1 is part of the battery backed memory circuit, but it should only be preventing the batteries from trying to power the whole circuit board. D1 is a 1N5817 diode, not a 1N4004. It also connects the memory chip to power when the game is on.
You could have a bad battery backed memory chip, and you have an ADDAMS FAMILY... Best pinball ever made!
It's WORTH it to put in a NVRAM chip in place of the original memory chip. That way D1 and D2 aren't as important, you never have to worry about changing batteries, you never have to worry about battery acid.
To put in an NVRAM memory chip is a difficult job, and unless you regularly unsolder IC chips and put them in sockets, you are going to want to send your CPU board and have this job done for you... but it's worth it, and if the memory chip stuff is the problem you will have both fixed the problem and made your game much more reliable.
Get the NVRAM memory upgrade, and have the technician who installs it for you check out the CPU... this problem is presenting as if you've got bad memory chip, bad ASIC (big square chip, problem might be fixed if it is squished in it's socket) or bad CPU chip.
You've got too good a machine to live with intermittent problems.
Let us know what you find!
