Also in, when the time comes.
Quoted from wolftownjeff:Perhaps make the spacer available as an option in the package? Depending on cost I would take one.
Waiting for led's for the bridge to complete.
May release the three before the center piece as thats a little bit behind in dev.
Quoted from Vimtoman:Waiting for led's for the bridge to complete.
Take your time. Good things come to those who wait. Can’t wait to see what’s to come.
Quoted from Vimtoman:Colors for Ultraman scoop mod.[quoted image]
Everything is looking great. Can this scoop mod be made in a translucent clear? Not sure if that is possible, but was thinking it might be cool since it could absorb the led light from all around. Also, can I order just this mod to get it fitted before my scoop hood gets bent so far back that it kills my beta capsule?
Quoted from RC_like_the_cola:Everything is looking great. Can this scoop mod be made in a translucent clear? Not sure if that is possible, but was thinking it might be cool since it could absorb the led light from all around. Also, can I order just this mod to get it fitted before my scoop hood gets bent so far back that it kills my beta capsule?
Yep will loook into it.
The transparent colored scoop mod lights up when lit with its matching color.
Just checking this thread for the first time in a while...OMG I am so glad you are doing the scoop mod! I should be on your list already, but I for sure will take the whole collection! Thanks so much for your work!!
Hi all, Sorry for the increasing delay on these.
Still waiting for a delivery of led strips from China.
Soon as they arrive will be able to conclude the bridge mod.
Hello, please add me to to to your list. I really like the look of your mods! The gunmetal bridge is fantastic and I can’t wait to improve the scoop shot. Hopefully these are ready soon.
Quoted from Giebzilla:Hello, please add me to to to your list. I really like the look of your mods! The gunmetal bridge is fantastic and I can’t wait to improve the scoop shot. Hopefully these are ready soon.
Waiting for led's the first lot where incorrect
Have a set of bridges done, beta capsules plus the scoops , soon as the led's arrive will be PM'ing
Quoted from paulbaptiste:Any hints at what the center piece mod will be?
I have three versions on going and thats probably my problem.
One has a display another just artwork and last one model with led effects.
I may end up with the last version but may combine . Not sure.
Quoted from Vimtoman:I have three versions on going and thats probably my problem.
Curious to see all 3
Will be contact people on the list and hopefully sending out at the end of Jan.
Royal mail hacked by Russia so no international post at the mo.
Still waiting for mine to come in. Looks like it’s taking its time. Can’t wait to make a great looking game look even better.
My mods showed up yesterday and today I took about 30 minutes to install all three of these awesome mods. Only issue I'd ask about is the connection for the RGB on the bridge are different connectors than what is used in the rest of the game and in the mod Splitter. I included a picture of the connections on my board to see if anyone has a suggestion or knows the right pigtail that will fix this. My game was LATE in the run (423) so maybe they changed it up.
Otherwise these are beautiful, and made a huge improvement in game play thanks to the scoop mod. See pics of it all installed (minus the lights) below.
20230222_165751 (resized).jpg20230222_165850 (resized).jpg20230222_165910 (resized).jpg20230222_165920 (resized).jpg20230222_170159 (resized).jpg20230222_170509 (resized).jpgQuoted from Var1AbL3:My mods showed up yesterday and today I took about 30 minutes to install all three of these awesome mods. Only issue I'd ask about is the connection for the RGB on the bridge are different connectors than what is used in the rest of the game and in the mod Splitter. I included a picture of the connections on my board to see if anyone has a suggestion or knows the right pigtail that will fix this. My game was LATE in the run (423) so maybe they changed it up.
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Ah rollocks!!!!
They changed the connectors?
OK will have to find out what connectors they used.
Quoted from Vimtoman:Ah rollocks!!!!
I spent some time under there and EVERY single LED as well as the actual light strips ALL use the exact same connector. The only ones that seem to have been changed were on the Pinataur board ONLY. So, I was thinking if I can sort out another spot to split the connection it would work fine. I will try and pull the PF back up and get some closeups of the exact connector they use. Regardless, BEST mods I have ever bought (well on par with Precision Flips on my R&M).
Quoted from Var1AbL3:I spent some time under there and EVERY single LED as well as the actual light strips ALL use the exact same connector. The only ones that seem to have been changed were on the Pinataur board ONLY. So, I was thinking if I can sort out another spot to split the connection it would work fine. I will try and pull the PF back up and get some closeups of the exact connector they use. Regardless, BEST mods I have ever bought (well on par with Precision Flips on my R&M).
Ive contacted Spooky but if anyone on here knows what type then i can send you a converter and add one in all the mods.
Sorry had no idea they changed it!
Quoted from Vimtoman:Think I found the connector type.
Var1AbL3 when Ive received them will make an adaptor for you.
Var1AbL3 If possible can you take a picture of the wiring connection to the led strips please.
Just want to make sure .
Yep thanks its the JST PH connector.
Have ordered a bunch.
Should have them in a few days time so will make two splitters types.
Quoted from paulbaptiste:I wish mine would show up already! Looking great!
Yours is stuck in Chicago customs ...
Quoted from Vimtoman:A picture of the front panel. Still a way to go.
Derailed train from bridge.
Large advertisment screen with shops and vending machines below.
Looking great!!
My mods finally arrived as well and installed them Friday! What a difference the scoop makes!
Thanks again!
Looks awesome Andrew, love it! The train sticking out of the building is genius.
Got back from vacation and my Ultraman Mods were waiting for me got them installed yesterday. Fit and finish is outstanding they look great and I really like the feel of the scoop shot now it feels way more solid. Looking forward to any other mods you make for Ultraman
IMG_1918 (resized).JPGIMG_1919 (resized).JPGIMG_1920 (resized).JPGThanks guy's .
Just finishing off the proto electronics.
Wanted the ability to change video's and allow expanding the number for future.
So should allow the modders modders tweak stuff
OK just waiting for PCB's to arrive so nearing completetion.
Thats if they are all OK.
If you would like any specific video clips to be added then please let me know.
Note the display is not a standard format.
I will add some animations of a billboard advertising type at launch.
Demo will be shown soon.
This page was printed from https://pinside.com/pinball/forum/topic/spooky-ultraman-mod/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
