Curious about the bottom left corner. Some sort of cut out and nearby coil there.
Is that another drop target bank on the middle right
Couple roll over switches and some stand ups.
If the subways feed to the in lanes, the servo driven towers must be a creative way to elevate the ball back onto the PF, without obstructing the inlanes? Like a flush flat topped elevator that lifts up and the ball dribbles out?
Quoted from SLCpunk2113:Those look like vuks that feed the inlanes from the subways but something else going on there. Maybe that’s where some stacking and loading happens.
Danessi lock 3 style...
Quoted from Pinash:If the subways feed to the in lanes, the servo driven towers must be a creative way to elevate the ball back onto the PF, without obstructing the inlanes? Like a flush flat topped elevator that lifts up and the ball dribbles out?
Lots of inserts and lamps around this area as well
Quoted from chad:Danessi lock 3 style...
I don’t think Danessi is design on this one but definitely think it looks like something that could hold multiple balls and then release them all at once. Bet it’s gunna be a crazy Multiball start sequence.
How long after the underside tease of RAM did we get a full reveal? A week? Two? These inlane servo elevator things look bonkers. I’m intrigued.
Quoted from dnapac:The two “towers” near the inlanes are different…must do different things.
I think they are the same just facing opposite ways.
I’m not saying it’s what it is, but all the subways down the left and right with multiple holes makes me think of Scooby Doo characters running between doors in a hallway. That’s not what this is (?) but that would be a crazy mech if they ever do a Scooby Doo pin
One looks like and elevator (quick return to the playfield), the other looks like a ratchet device…maybe a type of captive ball.
They are definitely different designs. Look at the the top of each...
Quoted from SLCpunk2113:I think they are the same just facing opposite ways.
I don’t think so…the one on the left has a wheel, the one on the right doesn’t.
Quoted from pinballkim:The underside of the playfield is up on facebook.[quoted image]
I flipped it vertically/horizontally (so we're on top). Looks like there's 3 right scoops and one left one on the main playfield, and possibly a drain from the upper left playfield that drains into the same subway, then on each side there's some sort of VUK. also obviously a 3-bank target down the middle
spooky_next_game (resized).pngThey are clock tower mechs and right before it gets hit with lightning Doc Emmett Brown swings down on them to the deloreon starting multi ball
Quoted from toyotaboy:I flipped it vertically/horizontally (so we're on top). Looks like there's 3 right scoops and one left one on the main playfield, and possibly a drain from the upper left playfield that drains into the same subway, then on each side there's some sort of VUK. also obviously a 3-bank target down the middle[quoted image]
Uhh didn't you just rotate this? The shooter lane is on the wrong side
That looks neat AF
I think they mirror imaged it to F with us haha
Quoted from Pinash:Uhh didn't you just rotate this? The shooter lane is on the wrong side
I bet those scoop holes are drain feeds from three upper playfields.
What if it is…left shooter instead of right.
Quoted from dnapac:What if it is…left shooter instead of right.
Never mind…that’s impossible the way it’s oriented.
That would be a real mind fahk haha. I’m all for it.
The 3 holes into the other subway do not have edge protection like the other subway entrance. So I doubt they are directly shot from the flipper. My guess is they are some sort of drop/entrance from another mech/toy on the playfield itself.
There is also a single drop target mech on the split playfield... and a drop target on the left side above the flipper area (but before the subway entrance).
ETA: looks like at least two drop-targets (or similar mechs) on that upper PF.
I'm still trying to figure out what is behind the 3 bank drop target set in the middle. You can see one stand up target clearly, and possibly another. Thinking it's a ramp entrance maybe...
I bet this things got ramps everywhere. It’s the Anti-TNA. Ima put them next to each other and see if I can summon a demon.
Remember…this is not fully built. Even if it looks like one thing, it may be something totally different.
Looking at the mode progress inserts in the center of the playfield definitely looks like stairs going between levels of a house or building.
Hey guys I just wanted to get ahead of this as I know there will be questions. As far as the 2 gear driven mechs go they are not the servo we have used in the past.
- These are a new driver that I have not been able to strip or damage even holding the arm as tightly as I can.
- These mechs have full clearance above them and below them and are unable to contact anything that could bind them.
- Ben Heck has been working on some super cool current sensing protection code for us.
- I will also note that as far as design goes you are able to swap and replace the entire mech with only removing 4 lock nuts.
- Both have 100% clearance to be removed without taking off any other parts or removing screws.
- We have over 6 months of daily use and testing on them with 0 issues.
We are doing better for you guys every single day and I truly mean that!
Quoted from SpookyLuke:Hey guys I just wanted to get ahead of this as I know there will be questions. As far as the 2 gear driven mechs go they are not the servo we have used in the past.
Bravo!
I’m on the edge of my seat. Theme is really important for me since my games go on location but I’m definitely liking your underside here spooky.
Build and quality are one thing, but the amount of soul that Spooky and crew put into their games is why I’m a total Spooky fan. I have a feeling, this pin is gonna be special. Can’t wait!!
Quoted from TreyBo69:Marked out some switches, holes, subway, lamps, and mechs I recognized and didn't
Ben Heck’s baby haha
Good grief, this is getting exciting!!! Having never owned a Spooky and knowing they are limited in #'s, are these things gone before actual release announcement?
Quoted from MK6PIN:Good grief, this is getting exciting!!! Having never owned a Spooky and knowing they are limited in #'s, are these things gone before actual release announcement?
Nope. Fang club members get first crack, but it’s after announcement and reveal.
Quoted from SLCpunk2113:Is it just me or does it look like the mechs in yellow are mounted to a different plain than the mechs in red?[quoted image]
stacked and loaded
upper upper playfield
Quoted from SLCpunk2113:Looking at the mode progress inserts in the center of the playfield definitely looks like stairs going between levels of a house or building.
It looks like three sets of "3 small/1 large" insert, could be modes structured like Star Wars etc. (i.e. 3 smaller modes, beat those to get to a mini-wizard mode, beat all 3 sets of 3 and get to the big mode at the top).
Quoted from SLCpunk2113:Is it just me or does it look like the mechs in yellow are mounted to a different plain than the mechs in red? I think we got a double upper playfield on our hands. Not to mention the one on the other side of the PF.
your on it
Quoted from BallyKISS1978:Please please please be Scooby!! Guaranteed my wife will let me purchase!
Please please please be a gory bloody horror themed pin, this way my wife won’t play it!
This page was printed from https://pinside.com/pinball/forum/topic/spooky-2021-game-speculation-thread/page/73 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
