Hi pbm3
in post-12 You write: "The W-Relay does pull in" - is this still true ? (we need the W-Relay pullinhg for "to add credits onto the replay counter".
Look at my snippet of schema: "A" is whre during play the Score-Drums and Specials make the "Add-Relay-Unit-Coil" fire.
The long green line shows the circuitry when You throw-in a coin into "2nd Coin-Chute". -> The w-Relay pulls-in and let the Score-Motor run - question: In Your pin ? Yes or No. Each turn the Score-Motor-Switch-1A pulses 5 times - This switch is good in Your pin - this switch is used allover in the pin.
There is an Adj-Unit - You can choose 2, 3, 4, 5 plays per coin - Can You set this to position-"5" ?
When adjusted "other" - some Score-Motor-Switches suppres some of the 5 impulses.
The pulling W-Relay throws a Make-and-Brake-Switch (Gottlieb does not want the Knocker sound WHEN ADDING CREDITS).
I like to use a jumper-wire - my "orange line" shows jumpering after the pulsed switch SCM-1A <-> Coil on Replay-Unit. This is complicated / hard to do.
A "much easier place to clip-on a gator-clip (jumper-wire)" is "at a switch on E-Relay" or "at a switch on O-Relay"
I do NOT want these relays for pulling - I do not want these switches for closing / opening !!! I just looked-up in the schema for a nice / easy accessible place to clip-on an jumper-wire (gator-clip).
My long "green line" is wire-color-black-mingled-with-white. AAA: Look on E-Relay for an Normally-Open-Switch with soldered-on: wire-color-black-mingled-with-white / wire-color-green-mingled-with-red - clip-on the jumper-wire at: wire-color-black-mingled-with-white. The other end of the jumper-wire clip-on at the replay-unit-Step-UP coil: at wire-color-yellow-mingled-with-green.
Throw-in a coin -> what happens ?
As an alternative - BBB: Look on O-Relay for an Normally-Open-Switch with soldered-on: wire-color-black-mingled-with-white / wire-color-yellow-mingled-with-green - clip-on the jumper-wire at: wire-color-black-mingled-with-white. The other end of the jumper-wire clip-on at the replay-unit-Step-UP coil: at wire-color-yellow-mingled-with-green.
(((pbm3 - I am frustrated - the schema says "at coil on Replay-Unit": wire-color-yellow-mingled-with-green AND the schema says "at Switch on O-Relay": wire-color-yellow-mingled-with-green)))
Somewhere in that (my green) long connection SCM-1A <-> coil on Replay-Unit: is a fault.
Greetings Rolf
P.S.: When Your testing gives replays -> we move the jumper-wire at the next place -> the to the next place -> all of a sudden: NO replays - the fault is no longer jumpered.
