In the process of bringing my Old Chicago back to life. I took the spinner apart, cleaned, adjusted, and lightly lubed it. It's spinning fast now! But I would like some opinions on adjusting the switch. I have mine adjusted where the switch juuuuust makes contact for a brief moment when the flap is perfectly upside down while spinning. I have attached a pic of what it looks like at rest in the open position to give an idea of how far apart the switch arms are. I did notice that having it adjusted this way means that the ball has to hit the flap hard enough to make it go completely vertical before it registers a hit. So if the ball barely tips the flap or if it very slowly goes through, it doesn't count that as a hit. So I'm wondering if this is correct? Or should I have it adjusted to where a much lighter hit will score? How do you have yours adjusted and why?
