Power is out again here at home. 2hrs so far today
I have yet to turn on a pin when on generator power. Should I worry about voltage/frequency issues or just play some pinball.
I have spike 2 games and a Generac 20kw whole home cng unit.
Solid state powersupply should be able to handle fluctuations, but best if you can plug the game into a UPS and charge that off the generator.
You get any hail damage? I have two cars and a travel trailer that got hit pretty good.
WE Energies is estimating 24-48 hours here.
Quoted from ralphwiggum:You get any hail damage? I have two cars and a travel trailer that got hit pretty good.
Man that's terrible!! These storms just pop up I didn't even realize it was coming until I heard the hail.
I haven't inspected yet. Hoping for zero issues.
Fridays storm in Oconomowoc did 5k damage to my brother's car and his house is getting new siding and roof.
Quoted from JonCBrand:Power is out again here at home. 2hrs so far today
Pull up the specs of your generator - less than 5% thd (wrt to sine wave output) is considered near perfect power and should play nicely with pins.
Can also use power conditioner or as others noted a UPS for each machine (so long as the UPS has sine wave output with thd less than 5%).
Quoted from P1nhead:Pull up the specs of your generator - less than 5% thd (wrt to sine wave output) is considered near perfect power and should play nicely with pins.
Thank you, I will look at the THD spec. I have them on a UPS but it is not a line conditioner and also does not have enough power to play just enough to catch a blip in the grid so I dont loose a game.
Edit, just says less than 5% so I guess Im good to go.
Thanks again.
Capture (resized).JPGYou should be fine and keep in mind most wall power isn’t perfect and usually a little over or under 120 VAC.
Depending on your UPS it won’t be much different than just plugging directly into the genset - you need a high end UPS that is line interactive or better yet “online” to do any conditioning.
This page was printed from https://pinside.com/pinball/forum/topic/spike-2-games-on-generator- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
