hi,
I noticed a problem in the game today
when the sandman is open, the opto sandman activates when I flip
I check the connections of the opto card, and everything is in place
when I move the wires, the card detects signals
when I flip, or a close coil is activated, it also triggers
so vibrations play a role
I have 2 ideas in mind, either it is a problem on one of the 2 optos, or it is the card that has a false contact ... in your opinion?
I will try to interchange an opto card to see ...
Thanks for your help....
it's good, it's solved
thank you LTG
I reversed the 2 cards OPTO to be sure that the problem came from the card
then I dismounted the card and I redid the welds of the 2 connectors
since problem solved
