Just got one of the new Spiderman Vault editions in...and I made this video showing all the differences between it and the original 2007 release! What do you think? Todd
A great video!
And compulsory viewing for all the skeptics who posted here:
https://pinside.com/pinball/forum/topic/rate-spiderman-ve-for-top-100
Quoted from toddtuckey:Just got one of the new Spiderman Vault editions in...and I made this video showing all the differences between it and the original 2007 release! What do you think? Todd » YouTube video
I've never met you Todd but I've seen tons of your videos. They're fantastic! Keep up the great work and thanks!
Ha yeah, you gotta love the Todd Tucky videos. I have a 2007 Spider-Man. There is a lot of differences between this and the Vault Edition. Namely sounds, callouts,and dmd effects. I could easily turn it into a vault Edition by installing the VE code but I prefer the Spider-Man movie themed version. Both are extremely awesome.
I'm editing this because I wasn't aware of the fact you can exchange the codes between 2007 and the newer Vault Edition. Thanks for the input guys thank you Todd!
Quoted from tk-the-jammer:Ha yeah, you gotta love the Todd Tucky videos. I have a 2007 Spider-Man. There is a lot of differences between this and the Vault Edition. Namely sounds, callouts,and dmd effects. I could easily turn it into a vault Edition by installing the VE code but I prefer the Spider-Man movie themed version. Both are extremely awesome.
From what I understand, code isn't compatible between the two
YES! You CANNOT put the original code on a VAULT....BEWARE! The Vault is running a later board system and will NOT run the old code! And thank all of you for your kind comments about the video...Tammy and I had fun making it on Sunday (About 5 hours of work this past Sunday, plus the footage with my wife filmed two days before which as another 2 hours). These videos do take time to make, but we have fun making them! Todd
TandT,
I always like the background noises and shop scenes in the videos. The editing,slapstick humor,details on machines and trivia always draws me in to watch another episode. Enjoy your chocolate!
Probably a dumb question, but if they're using a newer revision of hardware to run an updated software revision, why aren't they just using the new spike system?
Quoted from mbaumle:Probably a dumb question, but if they're using a newer revision of hardware to run an updated software revision, why aren't they just using the new spike system?
Cuz at the end of the day, it's still SAM code...it's the same code as the original, same logic, same music and sound FX...just animation and voices swapped out. Probably easier to just do that on its native platform than porting it to Spike.
This Video just made me think.. the original had 3 levels of brightness for the villain inserts. As you defeat each villain the light gets brighter. Does that happen with the VE LED's?
Quoted from JoeJet:This Video just made me think.. the original had 3 levels of brightness for the villain inserts. As you defeat each villain the light gets brighter. Does that happen with the VE LED's?
Not that I've noticed. They're always super bright.
The white arrow inserts stay partially lit to show multipliers on the original too but I haven't watched or played a VE enough to know how they handle that.
Quoted from Sinbad:great to see Stern kept the ANNOYING flipper hum!
It can be fixed. You loosen and tighten the coil stop (may have to engage the flipper with it a little loose). I've fixed two buzzing flippers on my ST and the noise hasn't returned.
Quoted from spidey:It can be fixed. You loosen and tighten the coil stop (may have to engage the flipper with it a little loose). I've fixed two buzzing flippers on my ST and the noise hasn't returned.
should be fixed from factory though don't you think?
I noticed a few of the playfield inserts are not lighting in attract mode...... oh I now see it was fixed...
Rob
Quoted from Sinbad:should be fixed from factory though don't you think?
Hundreds and hundreds of these machines are hand assembled. Statistics guarantee that some will buzz. Just like some connectors will work loose and some light sockets will fall out. Hand assembly. Guys with screwdrivers and air wrenches. This is not Toyota, nor will it ever be or should be.
Quoted from TimeBandit:Hundreds and hundreds of these machines are hand assembled. Statistics guarantee that some will buzz. Just like some connectors will work loose and some light sockets will fall out. Hand assembly. Guys with screwdrivers and air wrenches. This is not Toyota, nor will it ever be or should be.
disagree, it can be easily worked into the same QC process that is meant to identify decal defects.
Quoted from Sinbad:disagree, it can be easily worked into the same QC process that is meant to identify decal defects.
How do you know that? Maybe they could do something, but "easily"? If it was easy they would do it, no? You can want whatever you want, but you can't have your own reality in which guys with screwdrivers AREN'T putting these things together. A manufacturer doesn't WANT things to not be perfect, they just have to balance wants and desires with what is achievable in reality.
Is there a YT vid on how this is done?
My SMVE has no hum. My Metallica pro had a really bad left flipper hum, like the video. I tried a bunch of things without completely eliminating the noise until I replaced the backstop. No more hum. It's vibration in the stop that causes it. I think my factory stop just had a loose (rivit?) whatever that is on the back of the stop.
This page was printed from https://pinside.com/pinball/forum/topic/spiderman-vault-or-2007-tnt-video-shows-differences and we tried optimising it for printing. Some page elements may have been deliberately hidden.
