Quoted from markmon:Proof? Just saying so doesn't make it true. At this point, I will disbelieve this is an intended feature.
I shouldn't bother answering a response with that kind of attitude, but what the heck. My machine works correctly. Most of the machines I've played work correctly. Just because yours doesn't does not mean the feature doesn't exist. Search youtube and you'll find some working correctly (and some not). Here's one that clearly shows it at the 1:00 mark for multiball start and again at 1:30 for super jackpot:
(hope that works...manually copying the link from my phone..if not search for Spider-Man Pinball - Doc Ock "Fling Trick" by PacDork)
Search around RGP...there are plenty of posts referencing it back when the game was new. It's a feature that many have had problems with working correctly, but it IS a feature. Would a post from Steve Ritchie himself about it and why some do not work right be enough "proof" for you? OK then...here you go:
HELP! Spidey "Magnet Fling" not working
•Date: Sat, 14 Jun 2008 18:19:24 -0700 (PDT)
So, on Spider-Man, when the magnet grabs the ball, it flings it toward
Doc Ock...this sometimes happens for a Super-Jackpot as well.
However, as of the other day, my magnet isn't flinging anymore. It
grabs and holds the ball, and it seems to do a "Wind up" (that ball
drops back a bit), but instead of flinging at Doc Ock, it just gets a
limp "pull back" to the magnet and then drops.
What should I be looking at here as a problem? What about the magnet
mechanism would allow it to hold but not fling?
Greg
•Date: Sat, 14 Jun 2008 21:21:39 -0700 (PDT)
The only thing "different" is that I put a new circle of stealth mylar
over the magnet ....I had one on there, and it worked fine, but the
mylar was bubbling a bit so I replaced it. That's when the mag
trouble started. So - I took the mylar off...and it worked fine
again. Weird that it worked w/ mylar before but now it wont. What's
up w/ that?!
Greg
•Date: Mon, 16 Jun 2008 00:12:50 -0700 (PDT)
up w/ that?!
Greg
You are adding distance between the ball and the magnet, adding an
"indentation-allowable" substance between the ball and the magnet that
probably causes drag, and disallowing direct metal-to-metal contact
which substantially changes the strength/distance/direction of the
ball during "flings". You may expect problems continuously with the
mylar there. You got lucky with the first mylar. If you dump the
mylar, the game will work correctly.
Steve
Here's the link for that. Sorry I do not have access to google groups right now, but this is a different usenet archive:
http://newsgroups.derkeiler.com/Archive/Rec/rec.games.pinball/2008-06/msg08232.html
Not enough? How about a couple quotes from Pinball News's in-depth review parts 1 and 2?
"Doc Ock also has a trick up his sleeve in the form of a magnet set into the playfield. This is used to trap the ball when - once enough hits have been made - one of his modes is started. In some cases the magnet only holds the ball for a brief moment before doing a "shadow lock" fling of the ball against the Doc, but in others it is held there until knocked off by another ball during multiball. "
http://www.pinballnews.com/games/spiderman/index5.html
and..
"Doc Ock lowers to block subsequent shots, but the next time the ball hits him it is grabbed by the magnet in front while the quote "The power of the Sun.... in the palm of my hand" is spoken
A second ball is auto-launched onto the playfield but the first ball is flung by the magnet against Doc Ock to score an immediate jackpot which starts at 250K."
http://www.pinballnews.com/games/spiderman/index6.html
If that's not enough, I'm out of ideas for proof. Steve Ritchie is a pretty easy dude to get ahold of and I'm sure he could set the record straight. Email or Facebook him and I bet he'll respond when he gets a chance. Or ask him at Expo if you get there.
