Hey guys I just picked up a 2007 spider-man and im adding the shaker motor kit and cant get it to work any help world be great thanks
as far as I know yes I got the kit from curly @ little shop of games do I need to turn something on in the menu
Quoted from Turboderf:Hey guys I just picked up a 2007 spider-man and im adding the shaker motor kit and cant get it to work any help world be great thanks
It is a pretty simple set up if you bought the right kit.
If you think it is correct, make sure the Shaker is set to maximum in the code.
Then it should shake when you hit sandman
Quoted from Turboderf:as far as I know yes I got the kit from curly @ little shop of games do I need to turn something on in the menu
Yes. You have options in the game menu. I am not familiar with your machine so I am not sure where it is.
Have fun!
Can you provide detail on now you hooked it up? I just added one to my game a few weeks ago and it is a different set up than other games. There's only two plugs, one from motor to board and one from front of game to board. You don't use any of the extra wiring that comes with the shaker. I can't recall if there is a key in the plugs, but make sure they are oriented right on the board.
Quoted from Lermods:Can you provide detail on now you hooked it up? I just added one to my game a few weeks ago and it is a different set up than other games. There's only two plugs, one from motor to board and one from front of game to board. You don't use any of the extra wiring that comes with the shaker. I can't recall if there is a key in the plugs, but make sure they are oriented right on the board.
I mounted the shaker motor & SM PCB board I pluged the motor on one side of the PBC board and the wire that's right there from the game harness in the other side of the board I went into menu turned on shaker motor on to max and I get nothing from the shaker went into test the shaker still not working I did not use the sub harness that came with kit for there is no connectors for the sub harness
The three pin connector goes towards the back of the game not to the assessory plug on the right. I think it a brown stripped wire if I remember.
Quoted from Turboderf:shaker kit 502-5027-00 Rev B the game is running 1.4 version
Immediately update to 2.6 for starters.
I wish I could remember exactly what I did but when I added a Stern Rev B shaker to my 2007 Spiderman it didn't work right away either. I added a ground somehow and then it worked great. I just can't remember exactly what I did but the board wasn't grounded and one of the pins was ground so I basically pinned up a connector and grounded it.
Quoted from hoby1:The three pin connector goes towards the back of the game not to the assessory plug on the right. I think it a brown stripped wire if I remember.
this is not correct for SM. there is a special plug just inside the coindoor for SM that goes to the shaker board.
Quoted from Turboderf:I mounted the shaker motor & SM PCB board I pluged the motor on one side of the PBC board and the wire that's right there from the game harness in the other side of the board I went into menu turned on shaker motor on to max and I get nothing from the shaker went into test the shaker still not working I did not use the sub harness that came with kit for there is no connectors for the sub harness
it sounds like you have it hooked up right, you might want to check the connections at the motor to make sure they are on correctly. confirm also that the connections to the board are keyed and plugged in correctly. i don't know if code is an issue with the shaker, maybe you are running an older version that didn't support a shaker. You could also check that you are getting 12v out of the plug from the game using a meter. check the fuses on the shaker board. if all those check out, either something is wired backwards or you have a bad shaker board.
Ok the code has been updated to 2.4 from Sterns website.
Menu says that the shaker is installed, but it still doesn't work.
Quoted from 0geist0:Ok the code has been updated to 2.4 from Sterns website.
I would take a quick photo of mine but I'm not home right now.
You may have a bad board, but check wiring harness again. Also Check fuses. Just because they are new does not mean they are good.
90% of these problems are a backwards molex plug.
The code on Stern's site is version 2.61
Quoted from DCFAN:The code on Stern's site is version 2.61
I just did it and I got 2.4
Quoted from DCFAN:For the original SM?
Yes, it says 2.61 on the file but 2.4 on the DMD
Quoted from 0geist0:Yes, it says 2.61 on the file but 2.4 on the DMD
Do you get the web bursts when the ball is bouncing around off the pop bumpers?
Quoted from DCFAN:Do you get the web bursts when the ball is bouncing around off the pop bumpers?
Yep, he sure does. And the pop bumpers are lit brighter
If it is doing the web bursts on the DMD during pop bumper action then it is 2.61, but it is very strange if it is saying 2.4.
https://pinside.com/pinball/forum/topic/colordmd-game-40-along-came-a-spider/page/2#post-3190670
Back when I installed mine several years ago, there was a connector on the left wall/side of the cabinet in the wire bundle a little past the tilt bob. That connector is for the shaker.
Quoted from eggbert52:Go buy another fucking shaker. End of thread.
Thanks for your helpful suggestion.
Quoted from 0geist0:Thanks for your helpful suggestion.
BTW it's a brand new out of the box shaker from Stern
shaker kit was bought from curlys this past weekend NEW in the box
Quoted from DCFAN:Back when I installed mine several years ago, there was a connector on the left wall/side of the cabinet in the wire bundle a little past the tilt bob. That connector is for the shaker.
yes im using that connector
Quoted from ita47:I finally called Stern and they had to build me a different harness for the back box and send it to me and that fixed it.
Extra red wire. Maybe it could be added in ?
Something isn't right here. Here is the board that came with my shaker. Connector on right is the one to the motor, connector on left is what was inside the coin door.
I don't know what the harness you show is for, but it isn't in my game for the shaker.
Quoted from ita47:I had the same problem with my SM. The wiring is different on SM for some reason. I finally called Stern and they had to build me a different harness for the back box and send it to me and that fixed it.
[Image/post mismatch]
Quoted from Lermods:Something isn't right here. Here is the board that came with my shaker. Connector on right is the one to the motor, connector on left is what was inside the coin door.
There is a board similar to yours that mounts down in the cabinet on the left side above the shaker motor. The shaker motors purchased from Stern also come with a harness for the backbox with a ground wire that runs back down to the board your referring to. The harness I posted pictures of is that harness for the backbox. As LTG pointed out there is an extra red wire on the SM harness Stern sent me. All I know is mine didn't work until I installed the new harness.
Quoted from ita47:Just wondering if you ever got your shaker working?
nope I never got it to work so I trader the spider-man in on a NIB Aerosmith pro so im selling the shaker kit 502-5027-00 Rev B its New
This page was printed from https://pinside.com/pinball/forum/topic/spider-man-shaker-motor-not-working and we tried optimising it for printing. Some page elements may have been deliberately hidden.
