(Topic ID: 220967)
Spider Man doc Ock not always registering
By Coolpinballdino
  • 18 posts
  • 9 Pinsiders participating
  • Latest reply 2 years ago by Lobo2k
    #1 3 years ago
    Hi guys wondering if anyone has suggestions for this problem on my stern spider Man. Most hits on doc Ock are registering but I am also getting a lot of hits that don't register. I already replaced the transmitter opto and in test mode it works every time it seems like the only time it does not work is when the ball hits doc Ock super fast.
    #2 3 years ago
    Mine would do this just after I waxed the playfield, so your right about a fast ball causing it.
    #3 3 years ago
    Quoted from Coolpinballdino:
    Make sure the magnet core is level with the playfield. If not then the ball could be jumping off the core and over the opto beam I suppose.
    #4 3 years ago
    Quoted from DCFAN:
    Ok thanks DCFAN I will try checking that out tomorrow.
    #5 3 years ago
    Along the lines of what dcfan suggests, do you have a protector around the magnet that could cause the ball to jump? This was an issue with prison hits in twd.
    #6 3 years ago
    Quoted from Lermods:
    Ok thanks Rob me and my dad actually already checked the Cliffy protector and made sure it is flat and not causing a jump.
    #7 3 years ago
    The only other things I can think of are:
    1. A loose wire or bad solder joint on the optos, or
    2. You said you replaced the transmitter opto, but what about the receiver opto?
    #8 3 years ago
    A couple other things that could cause problems is having a reflective material such as stainless steel or having added lights in that area.
    In WOZ some people had problems with the orbit optos not working consistently because of the steel brackets they used for the optos were causing the opto beam to bounce/reflect off and not see the ball. They ended up changing the brackets to painted black.
    #9 3 years ago
    Ok thanks Rob i will tell my dad about changing the receiver opto.
    Quoted from DCFAN:
    Thanks DCFAN i don't think that is the problem though because i have not added any extra lighting or done anything different to the game it just started acting up recently.
    #10 3 years ago
    I believe the receiver opto and the transmitter opto are the same part number in SM. I would recommend changing both and make sure they are mounted lined up with the ball guide correctly.
    #11 3 years ago
    I had a carbon fiber cliffy on my Doc Ock magnet. It definitely caused the ball to skip over the opto sometimes. The Doc Ock figure would lower so it could be struck by the ball. Hard shots would hit the cliffy and the ball would jump over the opto and strike Doc Ock but not register. I also had a similar problem on TWD prison magnet that had a carbon fiber cliffy. Hard shots would hit the cliffy and skip over the opto. The ball would strike the prison door but not register. You may not think those thin cliffy protectors can cause the ball to jump but the absolutely do.
    #12 3 years ago
    Finally got back home to mess with spider Man I raised the magnet up a little bit and made sure it is even with the playfield and it's registering every time now. Thanks for all the help and suggestions guys.
    #13 3 years ago
    Quoted from rawbars:
    I had the same problem and uninstalled the carbon cliffy and installed the very thin metal cliffy. This works perfect now.
    Also, you have to ask Cliff for the metal version.
    #14 3 years ago
    Now is a good time to buy an infrared detector.
    #15 3 years ago
    So tangential to the original problem, but anyone else have problems with the ball bouncing back out of the Doc Ock hole with a direct shot? It's frustrating, so not sure if it is common or if foam, adjustments, or what might help if you did. Thanks and glad you got the original problem fixed.
    #16 3 years ago
    Quoted from Strohz:
    Most people put rubber foam in back. Common problem.
    #17 3 years ago
    Quoted from cpr9999:
    Thanks, my friend has one and never has an issue so I wasn't sure if it was an adjustment on mine or common. I'll try some Pinbits foam.
    1 year later
    #18 2 years ago
    Quoted from Strohz:
    OMFG, I just waxed my table and haven't been able to land a single shot. Was fine before, never a problem. Balls are flying now lol I can't even play the game. Hopefully it calms down in a few weeks.
