Williams Space Odyssey
After you light the A-B-C feature below the swinging target, the red "Special" light comes on in the left outlane.
Something is supposed to make it switch to the right lane and switch back, but it stays on the left.
Also, the match stepper does not advance.
After fumbling through the schematic I found a Change relay and a Number alternating switch involved.
I found the Change relay, cleaned all switches, it looks OK, but where is the no. alt. switch?
Maybe in the number match relay?
Also, I just worked on the flippers, new coil stops, plungers, springs, sleeves.
One flipper "flutters" on the initial stroke.
Help!
