(Topic ID: 251628)
Special Force Left Sling Not Engaging
By PinballGurus
2 years ago
  • 11 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by Inkochnito
#1 2 years ago
Works when transistor grounded. Makes sounds when hit, but won’t engage. Ideas?
#2 2 years ago
When you ground the tab, you are only proving the path from the transistor legs to the coil is good and coil works.
Doesn't mean the transistor is good or something back upstream from it isn't doing it's job. Or signal from MPU to driver board type stuff.
#3 2 years ago
It is an option in the menu....
#4 2 years ago
To turn it the sling on or off?
Quoted from Inkochnito:
It is an option in the menu....[quoted image]
#5 2 years ago
Quoted from PinballGurus:
It says: 0=no slingshots, 1=yes slingshots working.
#6 2 years ago
Yes, strange option for some of the 6803 games. But it would turn BOTH on or off, so if the other one is still working, this is not your issue.
#8 2 years ago
That would only leave a problem at the board....
Either the CA3081 (U19) or the decoder is broken.
#9 2 years ago
What’s the decoder?
#10 2 years ago
What’s the decoder?
its a 74154 chip on the MPU board. The PIA sends four bits in which decodes out to 16 possible combinations of outputs. Put the game in solenoid test and check activity at the 74154 chip with a logic probe or even a DMM on volts DC should be good enough as the transistions/pulse are slow enough. If the decoder output is good about all that is left is the CA3081 transistor array.
#11 2 years ago
What’s the decoder?
That would be U14 on the board....
