Quoted from MightyGrave:
Hey Guys,
I would Like to Install the speaker lights in my BM66.
It hast the flipper-Fidelity Sound Kit installed.
Can i usw the one from mezelmods with some modificstions in the speakerpanel?
or is there another one Kit you can recommend
Thank you and best regards
Mighty
You can use my Standard ($65) or Deluxe ($85) SPIKE 2 Speaker Light Kits with Flipper Fidelity speakers. Depending on what type of spacers are installed with the speakers, things may have to be done a bit differently. If they have spacer rings attached to the front of the speakers....you would have to remove the rings. If thay are installed with a removable spacer block, you will just remove the spacer block.
You would also then have to remove the bars from the holes in your speaker plates or buy replacement speaker plates from me that already have the bars removed ($17.50 a pair). All of this is described on my website here:
http://www.speakerlightkits.com/Upgraded-Speakers-Type-11.html
I recommend my Deluxe SPIKE 2 Speaker Light Kits (type 12). 358 different color / color transitions with adjustable speed and brightness ($85).
Doug (SpeakerLightKits.com)
