(Topic ID: 226525)
Speaker induction on modern Stern
By northerndude
7 months ago
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 7 months ago by northerndude
#1 7 months ago
Hey folks, got my Monopoly yesterday, have it all set-up now and I have a bit of an annoying issue with it. There is an induction sound coming from the speakers from when the GI and lights blink. It comes across as mostly a low volume beep almost through the speakers. There's definitely a background hum on them also. Grounding problem? maybe?
Anyone had this issue before? Just want to know before I get crazy with troubleshooting.
#2 7 months ago
That is actually normal, just like DE/Sega games. There is a mod for the Stern Whitestar board set. Basically, from what I read in the past, the amp is overdriven on purpose so the game can be louder in an arcade. This leaves a higher background noise at lower volume levels.
I know there is a thread on it, but likely someone else will find it before I do.
#3 7 months ago
Ok, wow, its loud. I have a Baywatch and it's nothing like this. I tried searching speaker induction, somehting else, but didn't come up with too much. Might have to do a better search.
#4 7 months ago
From pinwiki:
4.10.2 Loud Hum and/or Distortion at Low Sound Levels
Stern released Service Bulletin 133, which discusses a fix for a loud hum and / or distortion when the master volume is set below level 4. The machines that are specifically effected are Monopoly and Austin Powers. However, it has been over 10 years since these games have been released, and boards get transplanted to other games over time. So, it is important to check the two resistors (R106 and R110) in the amplification section of the CPU / sound board to see if the correct values are installed, regardless of the game. The correct resistor values should be 33K ohms 1/4 watt for R110 (ORG-ORG-ORG-GOLD), and 10K ohms 1/4 watt for R106 (BRN-BLK-ORG-GOLD). Consult the service bulletin for more details, and the layout of the amp section. The R106 and R110 control the analog volume. When these resistors are broken (open) the analog volume goes to 100% and can't be controlled via the buttons (digital volume) on the coin door. The higher the resistor value the higher the volume.
Another method of accomplishing the same thing, without removing and replacing a resistor, is to add a resistor to the back of the board, across R106 and R110, creating the equivalent resistance as mentioned above. A 4.7K resistor seems to be a sweet spot.
Yet another method used is to clip a 10K trim pot across each resistor. The trim pot can be adjusted to a good compromise between hum and volume.
#6 7 months ago
Thx moto_cat!
This pin was HUO, so there hasn't been any service bulletins completed on it.
$ 50.00
5,000
Fleetwood, PA
Metal-Mods
$ 40.00
