The other day I dropped both a ColorDMD and LEDOCD in my TAF. I now have a speaker hum/buzz coming from the left speaker. Any ideas? I have the same setup in other machines but no hum.
My first thought would be to try moving the speaker wires around a bit. If the wires are lying close to a switching ciruit, it's possible that it's picking up noise.
Did you connect the original ground wire or the new one that comes with the ColorDMD kit? (Or neither?)
Quoted from stevevt:Did you connect the original ground wire or the new one that comes with the ColorDMD kit? (Or neither?)
I connected the ground wire from the kit to the ground wire on the cab.
Hum is generally produced by ground noise from switching circuits. The screen itself has a switching LED backlight. The LEDs in your game are also being switched on/off by the LED controller.
Ground loop noise can be very difficult to track down and resolve. If it's possible to increase the switching frequency above audio frequencies that can help to "eliminate" the hum.
Right. At this point it appears to be coming from the GIOCD. The strange thing is that the GIOCD has been in the machine for a while, and the hum only started when the ColorDMD and LEDOCD were added. I've tried unplugging both and I'm still getting the hum.
Short of making sure the speaker cables are out of the way and the ground cable is firmly attached, I'm not sure what else to try without spending some time thinking about it.
Unfortunately, the GI OCD transistors aren't fast enough to switch above audio frequencies. Depending on which firmware version you have, it's either switching at 250 Hz or 1kHz. The 1kHz would be more likely to be something you would hear, so if you have v5 firmware on the GI OCD, we could try reprogramming it to v3. Feel free to email me if you continue having problems with it.
Make sure the speaker wire is not getting smashed by the ColorDMD. I had that problem once and had some problems.
I'll check the wire, thanks.
I did some more experimentation. Disconnecting the ground wire from the ColorDMD eliminates the hum. Obviously, I don't want to do that. Any ideas on how to safely ground it while preventing the hum?
Does disconnecting the ribbon cable that runs to the ColorDMD change anything?
Are you using stock WPC audio and video boards?
I tried disconnecting the ribbon cable...No effect.
What ended up working was I made a longer ground cable and connected it to the ground braid on the other side of the machine from the GIOCD.
This page was printed from https://pinside.com/pinball/forum/topic/speaker-hum-after-colordmdledocd-install and we tried optimising it for printing. Some page elements may have been deliberately hidden.
