(Topic ID: 228037)
Speakeasy 4 - Match/Ball Display Issue
By crazi
5 years ago
  • 10 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by crazi
    #1 5 years ago
    Hi All - so I'm restoring a Speakeasy 4 and have it all done except for a weird issue. The match/ball display doesn't show up even though the display is working 100% in test mode. See pics. Sometimes during attract mode it does show "00" but goes off when you start a game. WEIRD!
    1st pic is at start up in attract mode
    #2 5 years ago
    Then shows in attract mode "sometimes"... when the "Match" light is on
    #3 5 years ago
    Then goes off again when you start a game...
    WTF??
    Any ideas???
    #4 5 years ago
    Are you using a Alltek, set to free play?
    #5 5 years ago
    No it's a standard MPU board
    #6 5 years ago
    Bump
    #7 5 years ago
    Well, there are many things that can cause this, but in my experience a lot of display-weirdness issues are due to connector issues, generally broken or corroded spring-clips in the female-side (I'm going to assume you've already tried a display swap to exclude that you're not talking cold-solders on the male-side). The problem with the "Display Test is OK" diagnosis is that all displays are being driven by the same digits at the same time, and some problems only show up when each display is driven separately as in Attract Mode or in-Game mode.
    Try popping out the wires from the credit-display connector one-by-one (you can just use a small jeweller's screw-driver to push the tiny spring-clip down and pull the wire out): You may find one or more bad ones that way.
    #8 5 years ago
    I've checked all the cables and everything seems ok. Yes I have swapped out the display as well.
    So works fine in self test and Match feature - just not when it should show what Ball you're on.
    Where does it get the "ball data" from?
    #9 5 years ago
    This is an add-a-ball game.
    Look along the bottom of your backglass. There are lights telling you how many balls are left to play.
    There is no "ball in play" on the display you're expecting it to be at on this game - those digits are only for the match feature.
    #10 5 years ago
    Quench - you are a star!!!
    I just thought it would show you on the display as well....lol
    This page was printed from https://pinside.com/pinball/forum/topic/speakeasy-4-match-ball-display-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
