New! Dark mode!
(Topic ID: 276378)
Spanish Eyes horseshoe question
By Geofflove
50 days ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 50 days ago by Geofflove
#1 50 days ago
Can anyone tell me what sort of posts/rubbers should go on the inside of the horseshoe (the ones either side of the gobble hole)?
I've not got into mine yet but can see there is no rubber on one and one of the posts appears to be snapped off. What do I need to order?
#2 50 days ago
They use T rubbers. PBR sells a machine screw post that can probably be used too, assuming there's nothing underneath. See "Tee-Rubber #6" here: http://www.pbresource.com/postscrew.html
#3 50 days ago
Ah great thanks. Once I get the thing open I'll check if the posts are just screwed into the wood or bolted through. Thanks
#4 50 days ago
Just FYI, the term gobble hole denotes a hole where the ball disappears under the playfield and does not kick back into play. Essentially, the player loses the ball. They are usually found on late 50's and early 60s machines that actually used 5 balls that would collect into a trough under the playfield.
Spanish Eyes was designed with a kick-out hole, sometimes called an eject hole.
#5 50 days ago
Ah ok. Thanks!
350
Charlottesville, VA
Lakeport, CA
$ 4.49
$ 40.00
Arcade Arts
$ 44.00
$ 90.00
Lighting - Under Cabinet
$ 149.99
$ 999.00
$ 7,599.00
$ 39.00
Concealed Art
$ 28.00
$ 99.99
$ 33.00
Metal-Mods
$ 4.49
$ 109.99
PinballBulbs
$ 139.00
Sparky Pinball
$ 29.99
$ 49.95
Pin Stadium Pinball Mods
$ 109.99
$ 254.99
