Hey all,
I'm a newbie so go easy...
I have an issue where the right slingshot coil gets stuck on right after power up and will not turn off unless I turn off the game. I was playing the game last week when the F7 fuse blew and the slingshots and pop bumpers didn't work and the flippers were weak. After taking the fuse out, it turns out that the wrong fuse was put in so I replaced with the correct one according to the manual (4A 250,slow-blow). After replacing and playing for about 10 minutes the right slingshot coil was stuck on and upon further investigation I found that the diode attached to that coil broke. I replaced the diode today and still having the same issue. Now I am totally confused as to where to start, anyone have any ideas?
Thanks,
Matt
