You can see what the mini-playfield looked like from coz6 pictures.
I used Novus plastic polish number 3, 2, and 1 on the plastic surface to get rid of some of the wear spots.
I used Blue Magic metal polish on the gates and the metal posts. Pads for cleaning gun bores worked great with both polishes.
The decal was lifted up in a couple of spots. I was able to lift it up from the narrow end to the the yellow striped section. I used the back end of an Exacto knife to help lift it up. I was surprised how strong the decal is. I was going to use Goof-Off to remove the old glue. Don't do it! It started to soften the plastic playfield. I then used WD-40 instead to remove the old the glue. I was able to stretch the decal and reglue it.
My old playfield was cracked from the heat of the lamps. I've ordered LED replacements. I'll have to wait until they get here before I install this playfield. Here is a picture of the refurbished playfield so far.
