I'm fixing a space shuttle for a friend and I'm a bit of a newbie on pinball repair, I've only ever restored arcade games before this. The single drop target for "T" that blocks the multiball ramp is not working. I followed the troubleshooting guide I found online for Williams system 9 and the coil tested good, the diode tested good. I then did what the guide said and shorted the collector leg for the transistor to ground and that did fire the solenoid. After that point the guide just says "Check the rest of the circuit" Being a controlled solenoid the rest of the circuit seems to be another transistor and a 7408 "and" gate. Not really sure what to check and what I'm looking for, for all the other tests the guide is straight forward as to what you're looking for (voltages, pulses etc.) but for this it just says check it. Anyone have any experience with this sort of controlled solenoid on system 9?
Thanks.
