(Topic ID: 83327)
Space Shuttle Missing Some Speech
By smileymatthew
5 years ago
  • 5 posts
  • 5 Pinsiders participating
  • Latest reply 5 years ago by Grauwulf
#1 5 years ago
Finally getting a major project SS together. I'm not very familar with the game so not sure what speech I'm acutually missing but I do know I'm at least missing "1" - I get a "Ready Pilot ...." but no "1". Also, when the countdown to the multi-ball I'm getting a "3-2...." no one. I seem to recall the "Scream" when you lose the ball in the outlane which I'm also not getting. The Speech board has 3 ROMS in it, am I missing one? Not 100% all the speech this game is suppose to have, anyone help?
- Matt
#2 5 years ago
I have a Cyclone with a similar problem. If I swap out the MB the sounds all work correctly. Still trying to pin down the exact problem though.
#3 5 years ago
Matt; I too am just getting into SS. I acquired it 2 weeks ago for too much $. But I worked for NASA for over 40 years so I had to have it when one came available.
I am also having sound problems; two actually. The first was a noise problem that I have temporarily addressed with some braid wrapped around the shielded 2 conductor cable coming out of J 16 of the big circuit card. I think the root cause is that the cable connectors used are not really suited for wire braid resulting in a poor connection to the circuit card. I will investigate it further the first time that I remove the circuit card. Meanwhile the temp fix eliminated at least 95% of the noise which was driving me crazy when the machine was powered on.
You can read the conversation thread about my second problem on my post further down in the list.
What does your machine do in response to the two sound diagnostic tests? I get no effect when I press diagnostic S/W 2 on the large circuit card located just to the right of the batteries. In response to the diagnostic sound test I get no sound for numbers 00-05 in the match display, a single sharp sound for 06, and what I think is the Shuttle blast sound for 07. Then it recycles back to 00. Note that in the manual it says the match display will cycle from 00-06, not 07.
I too get speech that is not as expected and missing speech as well. At the start of most balls I get "ready pilot abort" instead of ready pilot one.
#4 5 years ago
Bad speech ROMs are common on older games. Try new ROMs 1st and then sockets if needed.
#5 5 years ago
Also could be a bad connection at the ribbon cable between the MPU and speech board, or a bad cable. Try re-seating the cable a time or two to see if that fixes the problem. Could also be a cold solder joint at one of the pins on that header, cold/cracked joints are very common on older machines.
2,200 (Firm)
Sale Pending!
Ham Lake, MN
$ 76.95
$ 14.99
PinballElectronics.com
1,650
Sale Pending!
Fort Wayne, IN
$ 99.00
Pinball Sales
Yorktown Parts and Equip
$ 229.99
$ 21.00
$ 160.00
Id Rather Play Pinball
$ 87.00
