We are restoring two Space Shuttles side by side. We now have them playing but noticed that one machine has better flipper strength than the other. The kicker is, the one with brand new coils is the one that is weeker. We measured voltage at the coils and found to have only 38 volts at the flippers. Then we measured the other machine. It has only 40 volts. Now I know it should be close to 50 and both machines are reading low at this point.
We have already replaced almost all of the caps on both power supplies, and installed the new and quite slick little board with bridges and caps to replace the big capacitor and 2 bridges in the lower right corner of the back box.
Question: What else can be causing our low readings at the flippers? One machine is 38v and the other reads 40v.
