(Topic ID: 225910)
Space shuttle flipper coil power wires reversed?
By patrickvc
5 years ago
  • 9 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by patrickvc
#1 5 years ago
On my right flipper coil, the coil is weak when flipping from rest but strong when the EOS opens like it was wired backwards. If I flip the power and return wires on the outer lugs will I damage anything? TheEOS wires are on the correct lugs. Problem is each wire is blue on the right flipper and may have been accidentally backwards long before I got the machine
#2 5 years ago
Here are a couple pictures.
Left coil lug has a blue wire with purple stripe to coil lug, and a blue wire to EOS. Middle lug has a blue wire to EOS. Right lug has a blue wire to coil lug.
Hope this helps.
DSC00645 (resized).JPGDSC00645 (resized).JPGDSC00646 (resized).JPGDSC00646 (resized).JPG
#3 5 years ago
Thanks Lloyd. That’s how mine is wired, but why does it switch to high power when the EOS opens? It should be opposite. I’m running a 11630 parallel coil with cap instead of the 23600 on the right side only left side is acting fine
#4 5 years ago
If I hold my hand in front of both flippers if I tap the flipper buttons the coils are weak. Right worse than left. At the middle to end of stroke it finishes strong. Wiring appears correct on both flippers.
#5 5 years ago
A couple of pics for reference.
20180923_212128 (resized).jpg20180923_212128 (resized).jpg20180923_212254 (resized).jpg20180923_212254 (resized).jpg
#6 5 years ago
Everything looks properly wired. I swapped flipper power supply boards with another game and no change. Should I be looking elsewhere?
#7 5 years ago
Quoted from patrickvc:
How about a good pic of the coil in question so that we can see the coil winding leads and the wire colors.
#8 5 years ago
Blue with purple on left and blue on right. Measuring 67 volts before flip and 59 on right lug after flip. No voltage on left lug when hold
F8E697DF-E244-4032-A3E7-8B0F25978574 (resized).jpegF8E697DF-E244-4032-A3E7-8B0F25978574 (resized).jpegimage (resized).jpgimage (resized).jpg
#9 5 years ago
I found some coil movement and have since tightened things up and the coil seems to have that lost power back. Good for now I think
$ 33.95
2,200 (OBO)
Allentown, PA
$ 129.00
Cabinet Parts
Bob's Pinball Stuff
$ 69.00
Pinball Pimp
$ 65.00
$ 18.95
$ 50.00
Slipstream Mod Shop
$ 12.50
RoyGBev Pinball
$ 69.00
Pinball Pimp
This page was printed from https://pinside.com/pinball/forum/topic/space-shuttle-flipper-coil-power-wires-reversed and we tried optimising it for printing. Some page elements may have been deliberately hidden.
