I have a project Space Shuttle machine that I have been troubleshooting a few issues on. Most of them have been resolved but a couple really annoying ones remain:
-The ball trough eject (solenoid 2) tries to fire to eject the ball into the trough but just sits there and keeps weakly trying, quietly clicking. If I manually give it a nudge from below, it will fire out the ball. I have 3 balls in the game and have tested the 3 trough microswitches which are all working. The transistor tests good and was replaced anyway for good measure. The assemblies are all tight and appear to be aligned well. The coil/diode also tested good but was replaced for good measure. The same exact problem continues to occur. I even tried swapping a separate known good Sys9 board into it and it does the same thing. Any ideas?
-Also, the bell is causing me some confusion. It appears to be wired fine and dings fine during the solenoid test. However, when it fires during the game it causes an annoying buzzing-type sound, definitely not a bell ring. I watched it while it did this and the striker seems to hit the bell and just lock on, instead of going back and forth. I'm not experienced with bells so I'm not sure what this could be...
Any help would be appreciated. Thanks!
