I am having two issues with my space shuttle pin.
1st..there is this annoying buzz/hum coming from the back box all of the sudden..its constant...short video of it:
2nd...this is one thats been driving me crazy since i got the pin. The kickers, MAINLY the right one, keeps kicking repeatedly after activated. In the beginning it was only the right one and kept blowing the fuse when the piston arm would kick out and freeze. I replaced the solenoid and it stopped the fuse from blowing but the rapid kick was still there...it did freeze up once on me but i was able to turn game off before fuse blew.
I then took the transistors on the main pcb associated with the solenoids and removed the one for the right kicker and the game played with zero problems (minus the use of right kicker)..no fuse blowing or anything...so i then swapped the transistor positions thinking where ever this new transistor was placed it would make that solenoid go bonkers...it did not and the right kicker still went bonkers. I tested all the transistors and resistors in every bank of those transistors on the main pcb..they all checked in perfect.
So then the latest move was to replace the 22uf 25 volt caps on each kicker leaf switch, which i did today and now both kickers are going bonkers when activated though i must point out the left kicker works normal 95% of the time and when it doesdo a rapid kick its only one or two....the right kicker however is has a mind of its own.
I been dealing with this right kicker deal for months and still no resolution. The resistors on the leaf switches are good also.
A short vid of the right kicker:
I appreciate any help you can give me!
