i have a space mission game plays one player well but when i try a2 or 3 player it will play a four player game even though the 3 can play light is on the back glass then it gets stuck on player 4 ,the player unit in the back seems fine
but i noticed the player reset relay does not always fire after the last players ball drops wether its 2, 3 or 4 player game
it usually works with one player ok .should it fire after the last players turn is over ?is this controlled by a stack in the switch motor ? or am i wrong and should i be looking elsewhere .the ball count was also gets stuck sometimes,it fires by does not always seem to push enough to advance ball count, will clean it up again and clean the advance selenoid
really could use your help ,and thanks in advance for your help
