(Topic ID: 61052)
space mission final adjustment
By tommycrum
10 years ago
  • 16 posts
  • 2 Pinsiders participating
  • Latest reply 10 years ago by SteveFury
#1 10 years ago
hello eveyrone
this is a follow up from another thread seems that has gone cold
the last issue i have it's starting on the second ball have done the coin, ball units new sleeves and springs and cleaned. this one got me, been looking over the schematic and just don't see the problem on the reset it lights the ball one light but just as the start up sequence finishes it advances to ball two any help from you guy's would be great
#2 10 years ago
what i have found out is that the ball index is latched on in the start up sequence and also that the coin and rest relays drop off early in the sequence any answers as to where to go from here
#3 10 years ago
I would go back and check your score motor switches. These types of wierd problems may be one consequence of taking those switch stacks apart.
I've been working on a 1961 jukebox I got last week and it's been consuming all of my free time.
#4 10 years ago
thanks steve i know and thamks for getting back to me
please when you have the time look at the other post at the end just things i have been doing
i know thats a sweet juke box
#5 10 years ago
follow up
checked all the score motor switches they are fine
what i did now is open the switch at the left up ramp
the top one that was closed and left the bottom one open
starts on ball one plays until you hit that switch any help here
if i close the switch it starts and gives the game a ball advance and starts on ball two
help
#6 10 years ago
follow up
ball index relay stays on at reset no points scored
checked the 10 100 1000 relays and they are fine
manual says the only other thing that can activate it is the tilt relay but manual does not have a pic of the switches like the others
help please
#7 10 years ago
follow up
help please
This is a pic I used in a different thread of the index relay so you can ignore the red circuit path. If your index relay comes on at startup then there may be a switch stuck on one or more of the 10's,100's and 1000's relay in the head/lightbox.
It can also be that the self-hold switch on the index relay is closed. Here's another pic used somewhere else which maps out the index relay for you.
#8 10 years ago
follow up
thanks again steve
ok this is what the problem was
the left lane roll over switch which is a 3 bladed switch
they are supposed to be open and then close when activated the top two switches were closed
opened that one up and joy !
thanks to everyone !
game plays nice just have to do the score reels next but will wait on that until I get a few games in
lol
#9 10 years ago
ok got a new problem since I can play now
at 171,000 thru 179,00 it scores a game
it does score one I have set at 146,000
1st and second player does the same
#10 10 years ago
follow up
well I couldn't find the problem with the circuit for high but putting the orange high score pin in the
one slot stopped it from scoring 171,000-179 thousand now just get the hundreds to advance the thousands
3 weeks later
#11 10 years ago
ok problem since I can play now
and the hundreds don't advance the thousands
looked at the schematic looking at the eos switches
#12 10 years ago
ok still cant find the problem with the hundreds to thousand advance
everything else seems to be working well
a little help please looking a player unit but not understanding it
looks like it could be a voltage on it but haven't been able to find it
#13 10 years ago
I'd probably have to look at it myself to figure it out TC.
#14 10 years ago
I don't know if this will help or not but here's an unpublished video of the player unit movements through the 4 players. Not much excitement here though.
#15 10 years ago
thanks steve
what I think the problem is I don't think there is voltage to the circuit that goes to 100 to thousand
on the 9th position d u what voltage should be there and is it ac ?
thanks again for all your help
#16 10 years ago
All the lights run on a voltage of about 6 VAC.
All the solenoids and relays are around 25 VAC. The only exception are the two jet bumpers which use the 25 AC line then rectified to DC.
800 (OBO)
Oceanside, NY
$ 1.00
Pinball Alley
$ 50.00
Slipstream Mod Shop
$ 4.00
This page was printed from https://pinside.com/pinball/forum/topic/space-mission-final-adjustment and we tried optimising it for printing. Some page elements may have been deliberately hidden.
