I'm working on my son-in-law's Space Mission. The goal is to get it up and working so my two grandsons can grow up playing pinball. The machine has lots of problems that I can't resolve so far. So I will be posting a bunch here about it.
Problem #1. The Coin Door Mechanism won't let the quarters drop down into the coin box. Instead the quarters always get diverted to the coin return slot in the coin door.
I messed with this last night and couldn't figure it out. I saw how the coin mechanisms are spring loaded and open up to one side. I couldn't figure out if there was a way to divert the quarters down to the coin box so they would activate the little wire credit switches.
On the outside of the coin door there is a coin release button mechanism that is supposed to help you get your quarters back to the coin return slot. When I press on the button I see that a lever presses down on a bar that pushes some levers. It seemed to be working fine and not stuck in the down position.
When I activate the wire credit switch that the quarters would move, the credit wheel adds a credit....so that part is good electrically.
Any advice. I'll post a few photos tonight.
