Manual @ ipdb:
https://www.ipdb.org/files/2253/Williams_1976_Space_Mission_Instruction_Manual_Jan_1976_no_schematics.pdf
Schematic @ ipdb:
https://www.ipdb.org/files/2253/Williams_1976_Space_Mission_Schematic_Diagram_continuous.pdf
My Space Mission had a recently solved scoring issue that has been solved.
Now the previously working top rollovers are not scoring as they should. Both outer ones ((of the three))remain on / lit / will score target value. Noticed the CHANGE RELAY was locked on. Found that the match unit / alternator is not moving - believe it was fine 48 hours ago. Manually advance MU, CHANGE RELAY releases, lane lights both go out. So in my fixing I must have 'mis-poked'. Suggestions please.
