Hi Folks, Im having troubles getting 6 plays per 25 Cent coin out of my space mission.
Adjustments: 25 Cent: 6 plays, 10 Cent: 3 plays, 5 Cent: 1 play, 1 play for 1 coin 3 plays for 2 coins: off
As far as I understand, the following should happen if I throw in a 25 Cent coin:
First Step (highlighted green):
The 25 Cent Coin closes 25 Coin Switch and energizes the coil of the 25 Cent Relay.
Second Step (highlighted orange):
25 Cent Relay is hold by Score Motor switch 5b
Third Step (highlighted yellow):
Score motor ist started by 25 Cent Relay switch.
Fourth Step (highlighted red):
Credit unit Set Up Coil is energized through 25 C Re Switch and Index Score Motor Switch E. First play is credited. (Note on-off designators shown in the highlighted 1 Coin=1Play 2 Coins=3 Play Adjustment Jack would have to be exchanged in the schematic)
Fith Step (highlighted grey):
Scoremotor contact Imp-B pulses 5 times, Game 2 to 6 are credited.
The timing should look like this:
Actually I only get 5 plays. I verified, that the schematic is right (i.e. the path highlighted in red is open due to the 1 coin..1play adjustment jack). Now if the schematic is right, where should I get my 6.th play from (in the timing scheme this would be the first play)?
Patrick
