(Topic ID: 162269)
Space Jam: Wabbit Hole Protector
By CUJO
7 years ago
  • 21 posts
  • 9 Pinsiders participating
  • Latest reply 4 years ago by CUJO
#1 7 years ago
Hello Everyone!
Tried to "pretty up" my Space Jam some by adding a Wabbit Hole protector from Marco.
Went in really well. Covered up a lot of the touch up paint job the prior owner did (not so well).
It was almost level around the hole so no filling needed.
Problem is after the successful install of this protector, I can't get a ball to settle into the Wabbit Hole anymore..
A straight on flipper shoots airballs back at me off the guard that is installed over it.
I must have hit that spot 20+ times and not once could I get the ball to go in.
Only a hand rolled in ball works at this point.
2 questions:
1. Anyone else experience this after installing this protector?
2. What did you do to rectify?
I see where I might bend the cover guard down some to redirect or trap the ball better so am including a couple pics to let you see how mine turned out and if anything looks wrong to you.
CuJo
#2 7 years ago
I had the exact same issue. Have to bend the deflector a bit to compensate for the Cliffy protector.
#3 7 years ago
Quoted from vdojaq:
Looking at my side view pic..how does it compare with how yours looks installed? and working right?
It looks like I should just bend it forward at the base..maybe 5 degrees?
#4 7 years ago
I have the same issue with mine, I can never land the shot and I have tried adjusting it multiple times. I will probably just take mine off.
#5 7 years ago
I bent it down some..didn't help at all. Maybe if I line the deflector with some foam padding...it'll cushion that incredibly forceful shot.
If I'd known, I would have never bought protector...looks nice installed but game doesn't play the same. Haven't given up yet thou...
#6 7 years ago
I took mine off had the same problem mabey marco should be aware of this
#7 7 years ago
I bent the deflector shield down about 10% so the back edge of it was perpendicular to the base mount.
Still no good.
I'd love to hear from anyone that has installed/tweaked this so it works satisfactorily.
Maybe a SHIM to raise the deflector a bit and/or some sticky back foam padding on the front of the deflector plate to deaden
the balls impact...
or take it out altogether at some point....
#8 7 years ago
Quoted from CUJO:
put some washers under the scoop to elevate it, then put the scoop ontop of the washers. i did this with my cliffy, it elevated the scoop so the ball would drop. i found it was a PITA to get it dialed in, i just ended up selling the game anyways because the rule set wasn't much fun.
hope that helps.
#9 7 years ago
Quoted from Ballsofsteel:
hope that helps.
I sold mine too
#10 7 years ago
Getting ready to "shim" up the deflector, bend the deflector forward a tad to see if I can land a shot in this shallow hole.
Please let me know if someone has already shimmed this deflector up higher and if it made a difference at all so I don't waste time trying it.
Unfortunately, I haven't seen any "positive" results from anyone in this thread that has installed one of these protectors.
Looks great. Check.
Protects the playfield. Check.
Covers prior damage , sloppy repair work and bad touchup. Check.
Makes this WABBIT HOLE unable to land any shots unless they casually roll in. CHECK!
#11 7 years ago
just leave it off, mylar the whole area. i had the same issues with the art flaking off the monstars as well, and issues trying to get the cliffy to work with the scoop (i tried bending the scoop up and down and the top, as well as applying 1-2 washers under scoop). sure it looks like shit, but it will play well and the mylar will prevent anymore artwork flaking off the monstar area. just my opinion, its a 1300$ machine anyways.
#12 7 years ago
Well it didn't look that horrible from before. I just bought the protector because it was available and it made sense to install.
But if the game won't play right with bent or unbent deflector, adding shims, etc. then I'm taking it off the game and just leaving it as it was.
Never had any issues shooting the ball in the hole before. Never even realized this could happen but the hole is shallow and the metal doesn't absorb the energy like the wood does.
#13 7 years ago
I think one of us should share this thread with marco its like throwing money down the rabbit hole
#14 7 years ago
I think I'm going to call them and let them know Monday.
2 years later
#15 5 years ago
bump new batch of protectors and still the same issue. has anyone found a solution? if there a different back guard from maybe another game that would work better? does the washers really solve the issue?
#16 5 years ago
anyone have any advice?
#17 5 years ago
I would be curious if anybody has tried the washers and or deadening foam? I have one that's doing the same thing after I tried putting a protector on it. I guess since no one else has posted up about shimming or foam I'll try it and repost
9 months later
#18 4 years ago
Quoted from frank34obx:
Did you ever try the washers and deadening foam?
2 months later
#19 4 years ago
Anyone find a solution yet? I just picked up Space jam yesterday.
#20 4 years ago
I had the same issue, it's been a long time, but I think I added a little mylar in front of the protector. Then another small piece on top of that mylar. Kind of like small stairs. I think I found two small mylar strips in front, ended up fixing the issue.
1 month later
#21 4 years ago
Quoted from GJH:
Getting ready to try to use a Cliffy again. Can you post a pic of your Wabbit Hole if it was successful?
$ 54.99
$ 54.99
$ 18.95
$ 18.95
$ 17.00
Nordic Pinball Supply
$ 40.00
$ 54.99
$ 36.95
$ 18.95
$ 54.99
$ 22.00
arcade-cabinets.com
PinSound
$ 54.99
$ 12.95
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/space-jam-wabbit-hole-protector and we tried optimising it for printing. Some page elements may have been deliberately hidden.
