I picked up a Space Invaders a couple of weeks ago that was in need of a lot of work. I've fixed a lot of the cosmetic work and LED'ed the whole game. My last big hurdle was tracking down why none of the solenoids were working. After I repin J3 on the solenoid driver/high voltage board I should be good to go. For now I'm running a temporary jumper wire between TP1 and TP3.
My problem now is that most of the switches don't work. I've tracked down a switch matrix and the ones that work are all over the place. Specifically 6, 9, 10 27, 28, 29, 30, 33, 34 and 35. It seems like most of the working switches are in the bottom of the playfield. I've found a couple of ceremic capacitors and diodes that were clipped on one of their legs and I've resoldered them. Is there anything else I should check?
#space-invaders
