Space Invaders: Stuck switch
(Topic ID: 228987)
By Brewchap
75 days ago
  • 14 posts
  • 4 Pinsiders participating
  • Latest reply 74 days ago by Astill
#1 75 days ago
Running a switch test I found a stuck switch #5. This is a 50 Point Reb. (4), Drop Target, and 4 Top Bumpers. I checked each one to make sure that the switches were not touching or anything interfering on the bottom side of the playfield.
I also have a switch that's not registering. Spinner switch #4. At this point, I'm not sure what direction to go next to correct these issues. Any Ideas?
#2 75 days ago
I found a broken diode on one of the #5 switch. And Switch #4 started registering. Still have the same problem with switch #5
#3 75 days ago
Have you unplugged the playfield and tested the matrix at the board to see if you have a board problem or a playfield problem?
http://www.pinwiki.com/wiki/index.php?title=Bally/Stern#Switch_problems
#4 75 days ago
Quoted from YeOldPinPlayer:
NO! That's a great idea! Thanks
#5 75 days ago
Disconnecting the J2 connector (playfield) makes the error go away. Guess that I will stick my head under the playfield again to see what I can find.
#6 75 days ago
I found a switch matrix chart. https://www.pinitech.com/switch_database.php?name=Bally_Space_Invaders&printview=1
I checked everything in Roll 1 and in column 5. Still looking.
#7 75 days ago
Quote from PinWiki
(There is a special test rom available that will walk through all the closed switches one at a time).
Where can I find this rom?
#8 74 days ago
Are you checking these switches with a DMM/Ohmmeter, or are you just looking at them?
#9 74 days ago
Just looking at them
#10 74 days ago
Quoted from Brewchap:
You really can't trust just your eyes when dealing with electronics. I had an F-14 Tomcat that had a shorted upright target switch. The blades were not touching, yet the mounting rivet was shorting the sections through the base. It couldn't be seen, but only measured with a meter. Just like checking fuses....you can see the obvious open fuse, but sometimes there is a break that you can't see.
#11 74 days ago
Good point. I'll get the DMM out and check it out that way.
#12 74 days ago
Quoted from wayout440:
Sir you are correct! I un-soldered each switch then used the DMM to fine the one that was shorted. Thank you for the idea!
#13 74 days ago
Your welcome. I guess I learned a little something in a lifetime of electronics. Glad to share and help out!
#14 74 days ago
most of the time its the little cap has shorted.
Third Coast Pinball
Third Coast Pinball
Third Coast Pinball
Displays
PinballSolutions.eu
