I recently purchased a #Space Invaders Pin. It had been working fine except at times when the ball would bounce off a certain area, the machine would go out like it was tilted. I realized the whole game was lost and I had to start a new game. Gradually the situation got worse as to sometime the machine would only turn on and with a loud back noise and nothing else. And finally now I only get the lights to come up and not even the loud noise. Mind you after the noise situation started the credit button and the flipper no longer work. I am stuck at the same situation now. When I open the back board I only see a solid green light with no blinking afterwards at all. I think there was some work done on the harness with the molex connectors before I purchased the pin. I notice all the connectors are in but sometimes when I try moving the cables that are down at the rectifier board, the loud noise comes back. I still don't get any action on the machine. I also had one of the metal ramps come loose and it broke from the board. It is one of the ones that the ball comes down from leading to the flipper. Can someone guide me as to how I could trouble shoot further.
