Hi guys
I’ve got a space invaders I’m trying to restore
So far I’ve got an alltek mpu
Changed some connectors just
Checked fuses ,
Had all the boards tested working except sound board
What’s happening is ,
It’s turning on
Booting up and giving 7 flashes all be it the green lit is slightly dim when its went through the 7 flashes .
I can start a game.
It will play with flippers working and solenoids
The problems
The lights are just staying lit ,well some of them
They aren’t going through any sequence
I’ve tested for 5 v at points 2 and 3 on lamp driver board
I’d previously test the voltage on rectifier board ,right through to mpu
I’ve lost all the score boards lighting up
No sound ,though the sound board is one board that hasn’t been tested properly
Any likely causes or help would be appreciated ,the machine had been stored for years and wasn’t in a great state
Those connectors are a real pain if anyone could point me in the direction of any I’m particular that would cause the above problems
