Ok I have a Space Invaders machine most everything works. However I cannot seem to get some of the lower play field lights to work no matter what i do. Also only about 1/4 of the infinity back glass lights work. I have replaced the aux lamp board and the rectifier board. This fixed a couple issues. I found two blown transistors one on the lamp driver board. Replaced them. Re soldered all connectors and re pinned all rectifier board plugs. What else is there? I have checked every bulb and every fuse. Not able to get any further. Could the transformer powering the rectifier be putting out weird voltage? Could one of the ic chips on a lamp driver board be bad? All sounds, scoring, and solenoids work perfectly. Displays were replaced and work perfectly. Could the mpu board be bad?
