New! Dark mode!
(Topic ID: 197830)
The Last Starfighter Pinball
By pinteresting
  • 1,009 posts
  • 107 Pinsiders participating
  • Latest reply 4 months ago by pinteresting
  • Topic is favorited by 108 Pinsiders
    There have been 344 images uploaded to this topic. (View topic image gallery).
    30 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
    There are 1009 posts in this topic. You are on page 18 of 21.
    #851 2 years ago
    New speaker panel layout for TLS.
    #852 2 years ago
    3 layers and speaker mesh.
    #853 2 years ago
    #854 2 years ago
    Don't know if this matters, but all the knockers on my machines have a piece of metal that is mounted to the backbox/cabinet that the plunger slams against. Not sure if it is to protect the wood or to make it sound proper.
    #855 2 years ago
    Hah. This is a temporary main panel. I have some modifications that I'm working on for the layout.
    #856 2 years ago
    Quoted from pinteresting:
    How are you lighting the translite? Static LEDs in the backbox? Or will there be a swing-out B/W style board so you can have spot lighting animation?
    #857 2 years ago
    vireland I'm not sure. Due to the limited space in the box, I think I'm going to have to design a slightly deeper box but it's a bit unclear at the moment. We've just got the speaker panel mounted so things are just now coming together. We had a board blow up on Sunday so that has put a sever damper on things for the moment.
    #858 2 years ago
    Fortunately you have to deal with reality like blown boards. I just hang out here and throw ideas at you.
    You could also go the route of WPC-95 and have a tray holding the lights attached to the backglass itself. Since LED strips are so much thinner than 555s or 44/47s, you could make that attached tray REALLY thin and it would allow you to have a spot animated backglass using lights, which is something that I miss from the B/W days and would add to the retro feel of the game.
    #859 2 years ago
    This is all fantastic work. I enjoy reading on the progress.
    #860 2 years ago
    But, but, but you said you were past the hard part!
    In some ways blowing a board is a rite of passage, as it does indicate you are now getting into the real guts of wiring things up. Hopefully you will still have it flippable for CAX.
    My crystal ball sees very little sleep for you.
    #861 2 years ago
    azmodeus Thanks very much.
    rosh LOL. What does a blown component have to do with difficultly. Probably nothing. Shit happens.
    #862 2 years ago
    I am truely amazed at this progress in 10 months.
    #863 2 years ago
    lovelycoconuts Thanks. I truthfully expected to be much closer to complete by now but my work schedule has been really hectic since January. I'm hoping for a break soon.
    #864 2 years ago
    I'm looking forward to getting into modes and some rules when the game is up and running again. The manufacturing is fairly simple.
    #865 2 years ago
    Just starting some wireform ramp returns. I'm very much looking forward to making these. This is going to be fun.
    #866 2 years ago
    How are you going to go about it? Welding?
    #867 2 years ago
    wolfmarsh First pass is going to be soldering 260 brass rods and then plating them. Once they are proven, I'll move to TIG welding stainless steel rods and then electropolishing.
    #868 2 years ago
    Id love to see the process, on wire forms. excited to follow along.
    #869 2 years ago
    Ben did this while prototyping AMH. I forget how long they lasted, but at least long enough to test out the whitewood and bring it to the MGC show.
    #870 2 years ago
    @flipordie Ok. I'll try to document it as best I can. I'm no expert by any means. This'll be a first for me.
    @toyotaboy What is AMH?
    #871 2 years ago
    America's Most Haunted
    #872 2 years ago
    AMH is America's Most Haunted, the Spooky pin I think...
    #873 2 years ago
    Oh. Ok. Duh. Yep. Yeah.
    #874 2 years ago
    The idea is to cut these 1/8" thick brass ribs to grab the 1/8" rod once it's formed. That should give me a good wide surface to solder. Once these are soldered, they will be plated. The plating should help strengthen the overall construction a bit.
    "How are you planning on forming the wires?"
    Since this is completely modeled in 3D, I'm able to create forms with holes in them that should allow me to position my wires where they need to go. I have a couple ideas on how I'm going to do this but not sure if they will work or not. This is going to be fun.
    #875 2 years ago
    So this is the plan...
    I traced the footprint of the ribs (yellow outlines). I extruded the footprints so they create blocks that intersect the rails. I used the rails to punch holes through the blocks which transfers their position vertically and horizontally (notice that the holes get lower on the blocks). Now, I'll take the blocks and make them into 2D outlines and I'll cut those blocks out of aluminum or something that will not take solder. I'll mount them down to a plate and I'll start replacing them one at a time with a rib that will get soldered to the rails.
    pasted_image (resized).pngpasted_image (resized).pngpasted_image (resized).png
    #876 2 years ago
    Quoted from vireland:
    Here's the video showing a closer look at his early wireform ramps, you can see the solder joints
    #877 2 years ago
    Yeah. That game is great. I really liked it when I got to play it. I could've bought two pinball machines for what I've spent on this machine so far. I haven't told my wife what the costs are so far. She'd kill me.
    #878 2 years ago
    toyotaboy Yeah. Those rails are basically the same as what I'm doing. Mine will be quite a bit more stout and might actually hold up for a long time but the idea is to replace them with stainless rails or steel that is plated. I just love overdoing.
    #879 2 years ago
    The wire forms for horizontal shape.
    #880 2 years ago
    The current state of the design. Nothing more....yet.
    #881 2 years ago
    It looks awesome.
    #882 2 years ago
    agree with fifty , looks awesome
    #883 2 years ago
    fifty swinks Thanks. It's nice to be concentrating on the functions now vs. the overall design. I imagine that we have one, maybe two more revisions of the playfield to go before we lock this down.
    #884 2 years ago
    I see targets behind the up/down target assembly...
    Thank you, thank you, thank you.
    Awesome.
    #885 2 years ago
    Yeah. This is still a work-in-progress. Like I said, I think we are still about 2 playfield versions away from locking this down.
    #886 2 years ago
    Make sure the attrack mode sequence goes on and off like the arcade game to draw you over to play the pin
    #887 2 years ago
    And at the end you must decide to defend the galaxy or go back to normal life, maybe two different match endings, just random thoughts
    #888 2 years ago
    Quoted from Jackontherocks:
    Oh that's a good one, just like in the movie.
    #889 2 years ago
    jackontherocks LOL. I believe we are doing story modes but we're still more heavily into the mechanics stage right now. That's a great suggestion for sure though.
    mustangpaul I really like story mode rules in modern pins. It gives you a good sense of progression.
    #890 2 years ago
    I think they're talking about the attract mode and the match for replay. Attract mode totally makes sense. Great idea. The game goes on and off like when Centauri is getting close. Maybe it only does it every 10 min or something.
    Could also do that w/ the mini game inside the pin!
    #891 2 years ago
    bailorgana Ah. Ok. Yeah. That would make sense for sure.
    #892 2 years ago
    I wish someone would make an American McGee’s Alice in Wonderland pinball machine. That would be some cool stuff. Always really liked the artwork.
    #893 2 years ago
    Ah, yeah, I was wanting to play that game years ago based on the art, but somehow never got around to it. That would make a killer theme, especially if you could use holograms to make the Cheshire Cat show up in various places.
    #894 2 years ago
    thatonedude Yeah. I really think the artwork is fantastic and creepy and would make a really lush looking machine. It's a really cool twist on the old story.
    #895 2 years ago
    Oh dang. I just searched and saw that Popaduik was making an Alice in Wonderland machine. Well, I think an American McGee Alice would be way cooler long run anyway.
    #896 2 years ago
    I've been spending time catching the model up to the current playfield with cutouts and modifications that we've already made. Hole sizes, etc. It's becoming a ton more work as we move on. I'm glad we're onto the easy part.
    The modeling portion isn't really necessary but it allows us to visualize while we can't all be around the actual machine.
    #897 2 years ago
    Quite impressive!
    #898 2 years ago
    topher5000 Oh Thank God someone is. LOL.
    Thanks for the encouraging words. We're getting there.
    #899 2 years ago
    Hey I think it's impressive too.
    #900 2 years ago
    mustangpaul Yes but you are too easily impressed. LOL
    I was going to work on the wire form ramps this weekend and ended up getting food poisoning from pizza at work. Two of us are still out today from pizza Friday night from working late. Horrible. I was barely able to drink water over the weekend. I'm still hurting.
    Drink or food was instant convulsions from my stomach.
    $ 69.99
    $ 64.00
    Various Novelties
    Pinball Photos
    $ 54.99
    $ 68.50
    $ 72.95
    $ 80.00
    Back Alley Creations
    $ 229.00
    Tilttopper
    Playfield - Plastics
    $ 4.49
    $ 54.00
    $ 3.50
    Various Other Swag
    $ 40.00
    Arcade Arts
    $ 109.99
    Apparel - Unisex
    PinShades
    $ 33.50
    $ 18.00
    Ramp-O-Matic
    $ 29.95
    $ 47.00
    $ 4.49
    Sparky Pinball
    $ 11.95
