(Topic ID: 267041)
South Park pinball rom swap. Machine won’t boot
By nitrocow
82 days ago
  • 12 posts
  • 5 Pinsiders participating
  • Latest reply 82 days ago by Astill
#1 82 days ago
purchased the South Park profanity rom pack from Marco specialties, Installed them into my machine and now the machine won’t boot
Not sure if installed them wrong or the Roms are bad. Any ideas
I checked all the chips and made sure all the plugs are seated
Machine worked 100% before the swap
89BBD4EF-A50D-4B28-9DB5-41F8236D48F8 (resized).jpegCAFBF495-0171-4B52-820E-7D8A8114A825 (resized).jpeg46663250-665E-47AA-AD78-355DA654DD13 (resized).jpeg
#2 82 days ago
Did the notch on each chip line up with the white silk screened notch on the board ?
#3 82 days ago
May have one backwards. Let’s see if that’s the issue
#4 82 days ago
Quoted from nitrocow:
If you did. It is now bad.
LTG : (
#5 82 days ago
Look at the same board at Pinwiki. The ROMS on that board have the notches at the bottom. It appears every other chip on your board in the photo you posted also has the notch at the bottom.
https://www.pinwiki.com/wiki/images/1/1e/Sega_WS_CPU_Sound_520-5136-16_Rev._D.JPG
#6 82 days ago
The Roms are bad or the board ?
#7 82 days ago
Yep, you installed all the ROMS upside down. See the notch on the upper edge of the ROMS? Also notice the notch on the chip above it is pointing down? This notch points to the end of the chip that has pin 1. Typically all chips on the board have pin 1 oriented in the same direction.
You can try installing them correctly but chances are they are blown.
You should be able to install your original ROMs and they will work (you don't typically damage the board installing ROMs backwards)
#8 82 days ago
Just the ROMs.
#9 82 days ago
Joy haha thanks
I’ll see about getting a new set
#10 82 days ago
Don't feel too bad, we've all done it at least once.
#11 82 days ago
At least I can still order them. Thanks all for the help. Now I know what not todo
#12 82 days ago
Hi i can provide a new set for less. I am rompingirl on ebay but will do better on pricing direct. Also you do not want to use .90 cpu and display. They have many incomplete animations.
Gweem's Mods
Sparky Pinball
PinSound
$ 54.99
Arcade Upkeep
