(Topic ID: 43454)
South Park "kenny's revenge"
By ls1chris
11 years ago
  • 9 posts
  • 5 Pinsiders participating
  • Latest reply 11 years ago by ls1chris
#1 11 years ago
i bought a SP yesterday, in great shape ( for my liking and for me its HUO) did a coil/flash test and Kenny's flasher not working. flipped him down and the four wires going into him are all broken off ( probably from him flipping up and down)
my question is to remove him do i only have to take the two nylon lock nuts off of the bottom of him to remove him?
Mr Hanky is missing his right arm also and it's not in the cabinet if anyone has a busted one they want to part with i would bve interested ( you could just send remove and send a arm, either side i can re-form and then post it in place.)
i cannot beleive the black dust in the bottom of all the light inserts in the PF, is this just wear from the coil assembly's?
will compressed air remove this easily?
Chris.
#2 11 years ago
oh also just for now i pulled that harness into the cabinet and put a shrink tube on the 20V orange just so kenny didn't ground/arc/short out eeverything else.
the LED's on either side of Kenny, ( the white one) are those boards easy to fix or find? my one is out , once i get kenny out for wire repair i will pull that and see if i can figure that out too.
#3 11 years ago
Bump for a good dude. Upside down air spray (freeze spray) works pretty good to get the black dust out.
#4 11 years ago
you killed kenny!
#5 11 years ago
That black dust is a HUGE part of pinball, get used to it haha...you can also use a qtip and some alcohol to clean them...just don't waste your good drinking alcohol
#6 11 years ago
I got it sorted out, just a Phillips screw takes the light assembly out of Kenny so I could fix him up, I have an occasional ball drain issue popping where as the game won't recognize the ball was drained and starts popping coils in search for it
#7 11 years ago
Quoted from ls1chris:
This will be the ball trough. Either the microswitches or the opto at the end. The optos are famous for either flaky plugs or needing resoldering.
Clean the microswitches with electronic contact cleaner (non oil type) and make sure all the solder connections are good.
Also check the large molex that connects the whole trough to the wiring loom.
rd.
#8 11 years ago
Then enter SWITCH TEST MODE and roll a few balls down the trough. The switches should register every time a ball rolls over them.
Sometimes it's as easy as bending up the roller contact on the microswitches.
rd.
#9 11 years ago
Quoted from rotordave:
rd.
did exactly this today to check the opto's and they registered as per the manual instruction, i q'tipped them with iso , cleaned and reseated the opto board connectors, and the trough switches also registered but the very first one in the bank ( closest to the ball drain, furthest left) seemed to be lower than the others. i adjusted it up so to be similar to the others in alignment and kids are battle testing it now.
arcade-cabinets.com
$ 9.99
Daddio's 3D Printed Mods
Elkhart, IN
Gweem's Mods
$ 50.00
Duke Pinball
$ 54.99
Auburn, WA
Springfield, IL
PinSound
$ 0.99
Sparky Pinball
$ 54.99
5,900 (OBO)
Milan, IL
$ 19.99
$ 54.99
$ 19.99
$ 54.99
$ 54.99
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/south-park-kennys-revenge and we tried optimising it for printing. Some page elements may have been deliberately hidden.
