i used lamp cord to fix mine, it's meant to be bent and pinched without breaking like the original stuff does. i'll try and get a couple pics tomorrow.
if you flip kenny down there is 1 phillips screw that hold the flasher assembly inside of him. i still had some wire left on those connectors to work off of but i am pretty sure you could solder to them easy enough. pull it out and have a good look at it and sleep on it for a day or two, something will come to you for a lasting fix.
i had a larger orange wire, thats the 20v supply for the flasher, if it's loose pull it under the PF and wrap the end so it doesn't short out on a coil and fry something expensive.
can you pull it out and post a pic??
