Just purchased my first pinball machine a couple weeks ago so I currently have limited knowledge on fixing them and am looking for some guidance. I had a none functioning Mr. Hanky switch and that was easy to fix...just a loose wire.
What I cannot figure out is the issue I am having with Cartman. When I hit the Kenny hole, Kenny registers and when the ball rolls to the VUK, for some reason, Cartman will register. This does not happen all of the time but does happen 70-80% of the time. Also, when I hit the Cartman hole, it will sometimes register twice. This also happens 70-80% of the time.
What I have tried thus far: checked for loose connections (I checked everything all the way back to the motherboard), examined the switch under Cartman and everything looked fine (the gap appeared to be the same as the other switches), and reset the machine back to factory settings.
I got the machine on Nov. 26 and everything worked just fine for the first week.
Has anyone had this happen or have any suggestions on how to fix? I talked to the person I bought it from and also searched the internet for fixes but was unable to find anything that helped. I found one similar forum on this website but the suggestions didn't work for my exact problem. I figured I would post here before taking the next step of calling a repairman.
Thanks in advance for any suggestions.
