Dear Lloyd
Our resident pinball guru Lloyd Olsen answers Pinside readers questions!
Monday September 19th 2016
Lloyd,
I have a sega southpark with a very bizarre issue,
When you power the game up all the lights and the marquis come on for about 5 seconds then the marquis goes out and the play field lights go out, here is the bizarre part if you open the coin door the play field lights come back on and the marquee comes on after a few seconds the marquee goes back out but the play field lights stay on, the game will play and the sounds works just no marquee. there are no error messages that come up on the marquee that I have seen game name is displayed clear and there is no fading on the display.
So far I have checked the 4 bridge rectifiers on the I/O power Driver Board.they measure 499 to 590
All fuses, Re soldered all the cable connections to verify there were no cold solder joints
Checked the 2 ceramic power resistors on the display power supply board. both check to value
Cleaned all the board pins and connectors.
inspected all the caps and resistors do not see any that look burnt or blown.
Checked all the ribbon cables for continunity all checked good.
Game does have the Profanity chip set installed.
Any Help would be greatly appreciated.
Kenny
This page was printed from https://pinside.com/pinball/forum/topic/south-park-bonkers and we tried optimising it for printing. Some page elements may have been deliberately hidden.
