New! Dark mode!
(Topic ID: 282058)
Source for wire?
By rockwell
9 days ago
  • 6 posts
  • 5 Pinsiders participating
  • Latest reply 8 days ago by EEE
    #1 9 days ago
    Is there a source where one can purchase a relatively low volume of wire (or one-off chunks) that matches the colors of the original wiring under the playfield? Colors like solid light brown, yellow with black stripes, green with red stripes, etc.? Thanks!
    #2 9 days ago
    Planetary sells some. I use them for the common stuff.
    #4 9 days ago
    You can also make very passable striped wire yourself. Just need a drill and a paint pen set. I have a dowel with a hole drilled in it. That goes in the drill, thread wire through the hole, I clamp the other end in my vise. Spin the drill until you get a rotation in the wire every 1-2". Run the paint pen down the taught wire and then reverse the rotation. Let it dry -- striped wire on demand.
    Oddly certain colour/wire combinations don't work very well. I had water-based pens, probably oil-based ones would do better.
    #5 9 days ago
    Thanks for the heads up, I must have just sucked at searching on Marco. Appreciate it!
    Quoted from dr_nybble:
    Obviously I'm doing this now
    #6 8 days ago
    I’ve had surprisingly good luck at the local Ace hardware.
    $ 12.99
    Bent Mods
    $ 28.50
    Professor Pinball
    $ 1,099.00
    $ 79.00
    Lighting - Under Cabinet
    Arcade Upkeep
    $ 5,899.00
    Nitro Pinball Shop
    $ 84.95
    $ 18.99
    Playfield - Plastics
    Road Kings Ramp Set Out of stock
    Ramp-O-Matic
    PinBoss Mods
    $ 999.00
    $ 109.99
    € 30.00
    Creo Pinball
    $ 54.99
    $ 369.00
    $ 76.95
    $ 6,995.00
    Gulf Coast Pinball, LLC
    $ 48.00
    $ 8,999.99
    Music City Pinball
    Metal-Mods
    € 200.00
    Buthamburg
    $ 159.00
    $ 218.00
    $ 9.99
